Customs Custom Corvettes
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Feb 25, 2024.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
  2. Sky Six
    Sky Six
    from Arizona
    porkshop, Sharpone and Moriarity like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    is this louder?
  4. Sharpone
    Sharpone
    Sounds great
    Dan
    '40 Coupe Fan, porkshop and Moriarity like this.
  5. wheeltramp brian
    wheeltramp brian
    sounds great mark ,What is the exhaust on the vette?
    porkshop likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    Thanks, it is really loud and obnoxious kinda like its owner.... it has 2 1/2 inch rams horns and 2 1/2 inch pipe back to the mufflers that are 14" long Porter steel packs. with 2 1/4 inch tailpipes. The Porter muffler co was only about a mile from here and was run by a buddy of mine Clark Babler. When the Porter mufflers were first designed they were packed with metal shavings from a lathe. Sometime in the 90's they switched from using shavings to using stainless steel wool. Being the diehard old stick in the mud kinda guy that hates change that I am, I asked Clark if I could get mufflers made the old way and he replied. "If you want em packed with shavings, you have to bring your own and pack them yourself" . So, that is what I did. for this car, The 40 and my Impala
  7. wheeltramp brian
    wheeltramp brian
    Ha, that's crazy about the metal shavings.
    Moriarity, porkshop and Sharpone like this.
  8. Sky Six
    Sky Six
    from Arizona
    The weird shit you can learn, only on the HAMB.:D
  9. KustomCars
    KustomCars
    from Minnesota
  10. KustomCars
    KustomCars
    from Minnesota
  11. KustomCars
    KustomCars
    from Minnesota
  12. KustomCars
    KustomCars
    from Minnesota
  13. KustomCars
    KustomCars
    from Minnesota
  14. KustomCars
    KustomCars
    from Minnesota
  15. Moriarity
    Moriarity
    SUPER MODERATOR
  16. KustomCars
    KustomCars
    from Minnesota
  17. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Got that right
    jnaki and porkshop like this.
  18. KustomCars
    KustomCars
    from Minnesota
  19. KustomCars
    KustomCars
    from Minnesota
  20. I have no idea what year this one is, hopefully it fits in the theme of this thread. This is the only picture Ive ever seen of this car. Im curious to know more about it if anyone has anything they can share. Personally I like it, but Im sure its not everyone's cup of tea. e25f04a1ab638527fe8df9ce3a6f94d1.jpg
  21. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Looks like it started as a 63-67. I have seen that car before but know nothing specific about it.
    chevy57dude, porkshop and Sharpone like this.
  22. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Sure not much of the original left. I like it, though.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    that is a 64 Corvette called the XC11 by Dave Puhl. it was featured in rod and custom in Oct 1967
  24. Moriarity
    Moriarity
    SUPER MODERATOR
  25. Hey thanks for that info! Ill have to go through my magazines. Unfortunately they arent in any sort of order.
    porkshop, guthriesmith and Moriarity like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
  27. A guy named Bruce Camboni posted it on FB
  28. jnaki
    jnaki
    Hello,
    Corvettes as we all know, are the epitome of fiberglass sporty cars. If one likes Corvettes of all kinds, then the term fiberglass should not be a hindrance to enjoying hot rod building in any way, shape, or form. Whether it is a set of fenders or a tilt front end, fiberglass made its incursion into hot rods and drag racing from the early days.
    As the need for speed equated to lighter weight cars, fiberglass, however “truists” see as an abomination, made its way into all aspects of hot rods and drag racing. Of course, it is no longer our simple fiberglass cloth over a mold and shape into a creation of sorts. Now, technology has made molds as clean as normal steel shapes and the new tech becomes a different sort of construction. No more glass cloth over a crack or body shape, using resin to cure and now the itching continues the process.
    Learning how to work with fiberglass was a real treat. The early boat builders that sprayed fiberglass resin/shreds and other stuff onto the bare hull forms gave us a good whiff of fiberglass in the air at our nearby house in the Westside of Long Beach. The boat industry took some of its cues from the early GM factory. We eventually went to the factories nearby and saw the process. What an interesting concept. Hand laid fiberglass in coats + curing + finishing, although the molds were slick as glass, to spraying a thick glob onto the surface to make a nice shiny surface texture.
    The early cars were like early boats, rub your hand over the inside surfaces and one could feel the layers of sprayed on fiberglass. But, the industry and methods have improved. The insides of fiberglass boat hulls are like a mirror finish and rarely, does any one see rough fiberglass cloth surfaces.
    Jnaki
    So, does early Corvettes with a tilt front end become a “bad guy?” or does the acceptance of such technology fall into the need for getting lighter in weight and more speed?
    Since most of advancement? In drag racing fell into becoming powerful motors and lightweight bodies, then fiberglass and now, the new technology composite are in place. If one were to be in the time period of early hot rods and drag racing there was all metal bodies plucked from a junkyard or found in a overgrown backyard neighborhood. All steel and usually a little rusty.
    The need for having the lightest race car for any class resorted to lightweight fiberglass versus solid steel components. For the street, steel was the original factory build. But, in times of lack of parts or availability of solid build fiberglass or composite parts, then plastic or that method is acceptable.
    Afterall, no one goes knocking on fenders if something is in question or who cares is the final answer… it is hot rodding in its own version as part of a large, but really small portion of the public, doing its best to enjoy hot rods or drag racing as much as one can fathom...
    But, with all of the technology and style points, did we have to see the oddball rear wheel cutouts on one of drag racing’s most prolific builds in a stylish Corvette?
    upload_2024-12-10_4-12-19.png WHATTTT???
    At least, if we were able to build our own version of the 62 Corvette, it would have looked like this one below:
    upload_2024-12-10_4-13-20.png Nice clean lines and edges…YRMV
    Jim Bouchard and porkshop like this.
