Projects Currie Ford 9”?
Discussion in 'The Hokey Ass Message Board' started by Firedup, Aug 19, 2018.
  1. sunbeam
    sunbeam
    I built one for a friends 61 chevy used late 70s F150 axle cut drivers side tube to use short side after market 31 spline bronco axle came out 59.5".
  2. Firedup
    Firedup
    from Oregon
    6D4AF573-AA5D-48A8-97DE-05B1165D6580.jpeg 4BECDEDF-D73B-46E4-9D1E-1A7852EE013D.jpeg 956228A3-F181-4929-83CA-B31FA3D3005D.jpeg I ended up with this rear end. We believe it has 3.50 ratio. Not sure if I got 28 or 31 spline yet. Got it off a parts car. Needs a little tlc.
    Edit: I was told it was off a Ford passenger car, possibly a ranchero. Measures 61” wheel to wheel mounting surface.
  3. 41rodderz
    41rodderz
    from Oregon
    Where are you in Oregon ?
  4. Firedup
    Firedup
    from Oregon
    35 miles South of Portland
  5. Boneyard51
    Boneyard51
    That is a 31 spline.
    Bones
  6. Boneyard51
    Boneyard51
    That’s a 31 spline, IIRC.
    Bones
  7. I am building a 9 inch for my Cameo, and just lucked into 3 31 spline 9 inch pumpkins. I needed a new pumpkin, because the one I am replacing is the 9 3/8ths unit out of a full sized Ford, and the gear ratio sucks out loud.
    They are still out there, but a little luck helps.
    Bob
  8. The pictures above look like rear end came out of a pickup, springs are above the rear end. Id the bolt pattern 4-1/2" car, or larger?
  9. Firedup
    Firedup
    from Oregon
    6C4A99F6-459E-4ADC-BB8B-D82C51F484B6.png It was off a gasser parts car I purchased. 5x4.5 bolt pattern. Roughly 61.
    Edit: I was thinking it was 31 spine by the looking at the top pic and the identification info I found on the internet.
  10. squirrel
    pull the axles to find out...
  11. classiccarjack
    classiccarjack
    The 8 3/4" Mopar is thinning out too...
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  12. Bandit Billy
    Bandit Billy
    I recently purchased a nice 9" ford rear end from Jeff in Aloha, OR that advertises on Portland CL. He just happened to be sitting on a 9" housing for a Maverick that the guy didn't come back for. approx. 57" WMS to WMS. He centered the pinion, added a brand new Yukon durigrip, 3:70 gears, torino bearings, hardened axles. He normally doesn't have a housing so if you find what you want he can build it for you. Works out of his house and knows his stuff! And he is in your backyard @Firedup
    I paid him a small deposit, took about a week to get the gears I requested and build it out. I paid more 20 years ago for a rear end this nice. I have his cell number if you are interested PM me.
    Firedup and Blues4U like this.
  13. Mr T body
    Mr T body
    Alliance Vendor
    from SoCal
    Shortened 9" out of a '59 Ranch Wagon in my '31. Even came with a "N" case. Don't be afraid to go scrounging, it's half the fun!
    Firedup and Bandit Billy like this.
  14. DDDenny
    Interesting housing ends, how about a closeup shot.
  15. Bandit Billy
    Bandit Billy
    For you Douglas, anything
    Axles were drilled for both 5 on 4 3/4 and 5 on 4 1/2. I will use this guy over and over! What a great find locally.
    Firedup likes this.
  16. Beanscoot
    Beanscoot
    Minecraft?
    Man that's hideous.
  17. DDDenny
    Hey Billy.
    Curious, could you PM me Jeffs' last name.
  18. Firedup
    Firedup
    from Oregon
    Thanks Bandit Billy. I was actually looking at that ad quite a bit. I was after the 61” rear end. Glad to hear he does nice work. I may give him a call eventually. In my backyard is a bonus.
  19. 41rodderz
    41rodderz
    from Oregon
    Good info to keep. Always glad to here about someone who does good work.
  20. enjenjo
    enjenjo
    from swanton oh
    I think what you have there is a 65 to 68 Econoline rear end. 9" with 3.50 gears, spring perches on top, 10" brakes, big bearings, and a 4.5" bolt pattern. It is the same rear as a 60 to 64 Full size Ford with the spring perches on top.
    Firedup likes this.
  21. Beanscoot
    Beanscoot
    Could a guy flip that Econoline diffy over, unbolt and rotate the center section 180 degrees to get the perches on the bottom?
    You'd have to relocate the breather hole too.
  22. Firedup
    Firedup
    from Oregon
    Cool, thanks for the info. I was hoping someone would help me identify it.
  23. Firedup
    Firedup
    from Oregon
    8621A334-23C9-49F6-86F8-5D716D56772B.jpeg C735E3ED-8C47-464D-9C2E-9AC054C4C36A.jpeg D854782E-F93B-445F-A84C-ACC11071C111.jpeg 5C4C3421-356F-42A0-A31E-3742398943B3.jpeg
    I pulled the driver side axle. Looks like I got a 28 spline.
  24. Those look like ass :). Run a stocker or slightly modified stocker........Olds would be good. I've only had 2 rear shortened by Currie and both times were a pain, between up selling (one rear had a bent tube so they said with no leaks or noise) or missing hardware (they never want to give back the T bolts, even though they wanted the rear end complete and bolted together). Next time, I'll use Cooks machine.
  25. gimpyshotrods
    gimpyshotrods
    I found enough deviations from the "identify spline count by registration snout pattern" method, to render it meaningless.
    fauj likes this.
