Projects Currie Ford 9”?
Discussion in 'The Hokey Ass Message Board' started by Firedup, Aug 19, 2018.
  1. Firedup
    Firedup
    from Oregon
    Anyone using a currie housing? Are the fabricated 9” acceptable here? What other options do I have. Sources seem limited around my area. Strange? Etc. Looking to go to about a 62-63.5”
  2. 1946caddy
    1946caddy
    from washington
    Ford
    Outside Width (in.) Year Model
    56.50 1969-1977 Maverick 8"
    57.00 1974-1978 Mustang II 8"
    57.25 1957-1959 Ford, Ranchero, station wagon
    57.25 1965-1966 Mustang
    58.00 1966-1977 Bronco
    58.00 1964-1965 Falcon
    58.00 1977-1981 Granada/Versailles
    58.50 1977-1981 Versailles
    59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
    60.00 1967 Cougar
    60.00 1958-1960 Edsel
    61.00 1964-1971 Ford full size
    61.00 1949-1951 Mercury
    61.25 1957-1972 Ford F-100 pickup
    61.25 1960-1964 Ford full size
    61.25 1971-1973 Mustang
    61.25 1967-1973 Torino, Ranchero, Fairlane
    63.00 1970-1979 Ranchero & Torino
    63.00 1972-1979 Ford full size & intermediate
    63.50 1967 Fairlane (coil springs)
    65.25 1973-1986 Ford F-150 pickup
    65.25 1978-1986 Bronco
    65.25 1973-1986 Ford van 3/4 ton
    68.00 1972 Ford van 3/4 ton
    69.25 1977-1986 Ford E-150 van
  3. KustomKreeps
    KustomKreeps
    I prefer Moser to Currie. Not sure why just do lol.
    Both companies are great to deal with but I find Moser go that bit further to help you out and make sure you get everything right first time. Either company with custom make to what ever length you want.
    I put a 9" moser on the Hudson build in my sig.
    Sure cutting up diffs to suit the hotrod/dragster is traditional enough to be fine for the traditionalist police.
    Firedup likes this.
  4. Mike VV
    Mike VV
    from SoCal
    Currie did some excellent work for me a coupla years ago, for a reasonable cost.
    I'd go back.
    I know Moser also makes good equipment.
    Pick what YOU want, not what you may think is "acceptable".
    Toss a coin..!
    Mike
    chop job, TFoch and Firedup like this.
  5. gimpyshotrods
    gimpyshotrods
    Where is your area?
  6. Russco
    Russco
    from Central IL
    Raunchy, Chavezk21, Gammz and 2 others like this.
  7. Jkmar73
    Jkmar73
    from Tulare, CA
    I’m running a Currie housing in the back of my Model A that I am building. Easy to deal with and built to my specs. Would go with them again.
    Firedup likes this.
  8. banjeaux bob
    banjeaux bob
    from alaska
    if a housing from an S-10 is acceptable...most anything else should be too.
    Firedup likes this.
  9. Fab 9 and S10 stuff does not get a pass on the HAMB.
    A big web 9'' would be all you need. Don't call attention to the OT stuff on your car and you won't come under too much fire.
    Moser axles & nodular center section under mine.
    Firedup likes this.
  10. squirrel
    it's refreshing to see that a few guys here don't even know what a fabbed housing is :)
    mid 60s Ford half ton (five lug) Dana 60 would be a fun one....if you can find one. And it's usable.
    It's been over 30 years since Ford built a 9" rear, so the supply in wrecking yards is getting scarce.
  11. DDDenny
    Remember that magazine article photo about Currie years ago, there was a pile of nine inch rearends that was nearly a half a block long, thats where all those went.
    Firedup likes this.
  12. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Yep, I recall it stating that Currie had a standing contract to buy any/all 9" rearends from all the surrounding Orange County/LA wrecking yards. They'd set them aside in a separate pile for Currie. Must have made it tough for the average Joe to walk in to an LA basin wrecking yard and expect to easily buy one.
    As far as being "acceptable"; if your car is low enough, most folks will have a tough time seeing what's under it. The engine choice gets all the attention.
    Firedup likes this.
  13. squirrel
    I doubt this car will be low enough.
    Put a pontiac/olds rear in it, do it right
    Blues4U, Firedup and RICH B like this.
  14. Russco
    Russco
    from Central IL
    Quick Performance built one for me to my specs with .250 wall tubes and the early round back 9” housing. If they have any in stock they can build you one with the early center. If you are in the Midwest they are definitely worth checking out.
    kidcampbell71 and Firedup like this.
  15. Firedup
    Firedup
    from Oregon
    Portland/ Salem and surrounding areas. I’ve checked on a few. Either no call backs, wrong length, etc.
  16. Firedup
    Firedup
    from Oregon
  17. I am not sure where you are. I never have any trouble finding 9" Ford stuff.
    Strange makes a housing that looks like a 9" housing.
    I don't particularly care for a fabbed housing, I just don't like the look even on a late model. But they work.
    Firedup likes this.
  18. RichFox
    RichFox
    I had a Currie rear in my Lark. Looked like a Ford 9 inch. Maybe it was a repro. i don't know. Worked fine and I was happy with it.
    Firedup likes this.
  19. 4wd1936
    4wd1936
    from NY
    I have used a number of 9" units from SoCal, I think they are Currie. They have all proven to be a good investment.
    Firedup likes this.
  20. redo32
    redo32
    John's Industries makes new 9" housings. My buddy has used them.
    Firedup and INVISIBLEKID like this.
  21. Mr48chev
    Dutchmans was in the Portland area for years but moved to Meridian Idaho a few years ago. https://dutchmanaxles.com/?SID=4ae7af6d9d87540d9ac303173dc8ef44
    You would have to be pretty damned nitpicky to get down and look under a guy's car with a 9 inch and bitch because it had an aftermarket housing rather than a housing pulled out from under a donor rig.
    I haven't tried them but there is a shop 15 miles from me that is said to do a pretty good job modifying axles and cater to the 4x4 and racing bunch around here.
    http://www.ritchiesmachineshop.com/ I need to see them about doing one of the nine inch housings I have for my 48.
    That is about 2-1/2 hrs from Portland.
    Firedup likes this.
  22. I used Currie great product and service.
    Firedup likes this.
  23. finch6013
    finch6013
    from Oregon
    I went with Quick Performance for my 63 nova gasser drag car. Customer service was excellent, custom built to my specs, and the used a rear center section that looks like the originals. I've been running 10's to high 9's on it all season without any issues.
    Chavezk21, Russco and Firedup like this.
  24. Firedup
    Firedup
    from Oregon
    Thanks for all the great responses.
  25. banjeaux bob
    banjeaux bob
    from alaska
    Do a searc here on the HAMB for "s-10 rear" diff ....
    chevy57dude likes this.
  26. squirrel
    I think he meant S60?
  27. sunbeam
    sunbeam
    If you are not looking for a race unit a 8.8 from a 99-04 mustang is 62..5" and can be fitted with an E-locker. Open to locked with the flip of a switch.
    Blues4U and MO_JUNK like this.
  28. finch6013
    finch6013
    from Oregon
    I'v heard positive things about the 9'' housings and center sections from Speedway as well. Just another option to consider.
    Firedup likes this.
  29. Bob, you're right, S10 stuff gets a pass.
    But it it has nothing to do with traditional hot rodding.
    Let's not sway the OPs thread. He's asking about 9" rears.
  30. Firedup
    Firedup
    from Oregon
    I think I measured wrong. I was doing it by myself. I actually am wanting to go 60”. The 60 “ Speedway Motors 9” might be the route I take.
