So, i've got a '62 Galaxie with a 390cui engine. It has a bad Cruise o Matic trans. I was thinking about getting a rebuilt C6 to put in it. Does anyone knof it the C6 fits right on. In length, brackets etc?? Would appreciate an answer. Also..i would be interested in buyin a C6, or worse case scenario a good Cruise O Matic Thanks / Hank
Hi, I have a C-4 in my 1964 Ranchero and it works well behind a 350+ hp 302. I have encountered several people that are using them instead or a C-6. The C-4 is physically smaller and lighter and can be strong. Jan in Ojai, CA
My son & I replaced the Cruise O with a C-6 in his 59 T-bird. The case above the Torque Converter is larger on the C-6 but it still missed the firewall by 1/2 inch. The trans mount is in a different location but a simple plate will take care of that. I built him a new trans cross member since his FE is close to 500 HP. Trans to engine bolt patterns are the same but you'll need a starter for a C-6. Take care on the tooth count of the flex plate as well, I'm not sure if they are the same. Movin/on
