Crower cam #M4807 specifications? Also marked with X20F It's from a 225 "Odd-Fire" Buick V6 I am freshening for use in a custom 50's - 60's sports racer type car build. No luck finding anything at the Crower site. I will be freshening the engine so need the cam specs as I will probably have to get custom pistons. The old ones are fine but are slightly dished, I hope to up compression with flat tops. Also have just a bit more cylinder ridge than I am comfortable with for re-using the old pistons. And before the usual suggestions that I go with a 231 or SBC, this is to be a very vintage vibe build and this engine had a LOT of trick work done to it. Can post pics if anyone is interested.
I've already emailed them but judging from several other post here I do not expect much help from them.
Yep, I reached Sargent Schultz, "I know nothing!" So still looking for someone with an old catalog to help me out.
