Technical Cowl steering
Discussion in 'Traditional Hot Rods' started by Wildbill29tudor, Dec 9, 2013.
  1. Wildbill29tudor
    Wildbill29tudor
    I have searched around on here for the past 10 or 15 minutes with out much luck. Is there a how-to thread on here for cowl steering set up on a model a?
  2. oldsboy
    oldsboy
  3. willymakeit
    willymakeit
    There are a lot of them. Look up reversing steering boxes also.
  4. I did one on my model a and got most of the info in here, search cowl steering.
  5. Koz
    Koz
    Here's a couple of pics of how I did my Sport Coupe. The car was so low the column ended up through the dash. It had great lines of site and sat well. I couldn't get a pitman arm the right length so I fabbed one, Pics tell the story.
    Used the Mopar box and everything else was home made.
  6. Ted H
    Ted H
    I've read every thing I could find on the HAMB for the past two years on cowl steering and the best I've found is on Guernsey boy's build thread for his Model A coupe. Find his build thread and look starting about page 16.
    Ted
  7. F-6Garagerat
    F-6Garagerat
    It's page 13, Here's the link.
    http://www.jalopyjournal.com/forum/showthread.php?t=556599&page=13
  8. ty johnson
    ty johnson
    I used a Chrysler box on my 36 IHC. This is a pic before some extra bracing.
  9. willymakeit
    willymakeit
  10. rottenleonard
    rottenleonard
    Ty, Did you use any kind of bearing support out at the end of the tube?
  11. toreadorxlt
    toreadorxlt
    from Nashua, NH
  12. toreadorxlt
    toreadorxlt
    from Nashua, NH
  13. rottenleonard
    rottenleonard
    That pitman arm looks way cool, I like the pontiac emblem good touch!
    ps ya should fix your pictures so they are verticle instead of horizontal.
  14. tom brown
    tom brown
    the box pictured is 60,s to 75 mopar non power. does not require reversing and you can achieve just about any ratio you like. I cowl steered several with good results.
  15. Wildbill29tudor
    Wildbill29tudor
    What 60s to 75 mop at box? What cars would I need to look in?
  16. ty johnson
    ty johnson
    I sold the project before it was 100 % street ready. When it was finished, the guy who bought it did add a support bearing. I told him too, and at first it wasn't done and it did have movement.
  17. ty johnson
    ty johnson
    Chrysler B Body.
  18. Wildbill29tudor
    Wildbill29tudor
    Wow I had an auto correct issue there, glad you guys knew what I was talking about. Ty I must say you have been very helpful in answering a lot of my questions. It's very much appreciated!
