Technical Copper-nickel brake lines
Discussion in 'Traditional Hot Rods' started by studebakerhawk, Dec 13, 2024.
  1. B_Griswold
    B_Griswold
    from Greer SC
    That’s the way to go. Used it on my ‘41 Plymouth. Easy to bend. Look into line straightening tools to get a good straight line for the frame rails. Simple trick is to just drill a hole in a piece of wood and slide the line through it. Use a bending tool! Tweak bends with your hands. Make sure you put fittings on before flaring and in the correct direction! Haha!
  2. Busmania
    Busmania
    from Denver
    I used Nicop on my 40. I also used it on the fuel line. However, for the fuel line it had a black flaky stuff that clogged my fuel bowl within minutes. So I went back to rubber for the fuel line. I’m about to switch it out for braided rubber.
  3. Beanscoot
    Beanscoot
    Something strange here... obviously black flaky stuff would be really bad for brake systems too.
    Actually worse than for the fuel system.
    lothiandon1940 and gimpyshotrods like this.
  4. chicken
    chicken
    from Kansas
    "I used Nicop on my 40. I also used it on the fuel line. However, for the fuel line it had a black flaky stuff that clogged my fuel bowl within minutes. So I went back to rubber for the fuel line. I’m about to switch it out for braided rubber."
    Yeah, that's not normal. The particular piece of line you were supplied with must have been contaminated. All the stuff I've used was bright shiny clean and remains that way in use.
  5. Fortunateson
    Fortunateson
    Well I don’t know how I feel about you cheating and giving the answer to the whole class?! I wanted the class to review the periodic table...
  6. arse_sidewards
    arse_sidewards
    from Central MA
    You're thinking of straight copper. Nicop is much more forgiving. The average flat rate tech is a complete dumbass and even they manage to work with it.
    chicken likes this.
  7. chicken
    chicken
    from Kansas
    Oops.....:(:D
    Dave G in Gansevoort likes this.
  8. Dave G in Gansevoort
    from Upstate NY
    Now it'll be on the final! Good going...‍
