Converting the Banger motor from 6v to 12v
Discussion in 'The Hokey Ass Message Board' started by notebooms, Nov 7, 2010.
  1. notebooms
    notebooms
    Alliance Member
    I've got a cool old 6 volt early Mallory/Holley coil and early Mallory distributor on my pre-WWII styled, 4 banger powered hot rod project.
    I love the look of my current 6 volt coil on my firewall, but i'm thinking of converting to 12 volt negative ground, from current 6 volt positive ground. Reason: i drive the hell out of my cars and 12 volt is just easier to deal with out on the road.
    QUESTIONS:
    1) I really dig my coil and don't want to change it. Can i run this 6 volt coil at 12 volts? I assume i'll have to switch polarities when i convert to negative ground (right now the positive runs to the points) ?
    2) Know anyone who converts early generators to 12V alternator inside?
    Appreciate any help and input. Thanks,
    -scott noteboom
  2. search the earlier threads on the subject... and as for your coil maybe a good ignition ballast resistor might work to drop the 12v down to what the coil will tolerate...
  3. notebooms
    notebooms
    Alliance Member
    found right ballast resistor and will give it a try. thanks...
    -scott noteboom
