Technical Converting my Ford/Mercury steering wheel to GM spline
Discussion in 'The Hokey Ass Message Board' started by matthew mcglothin, Mar 3, 2020.
  1. matthew mcglothin
    matthew mcglothin
    This may have been done before but I thought I’d post this anyways for tech. So I wanted to run a 55 Mercury Montclair wheel in my 46 ford p/u but I have a gm column with 69-94 spline...yes I know.. cheesy chrome tilt but it works for me being 6’3” in a 46 cab. With a local u-pull it nearby and the design of the 55 wheel I figured I could pull something off fairly easy. I picked up an 86 gm van wheel for $12. It had almost the same thickness and diameter hub as the Mercury wheel.
    55 wheel
    Gm van wheel with center cut
    Comparison with mercury wheel
    Cut and welded center hub from van. Drilled and tapped holes for the horn ring.
    In the end it still looks like a factory wheel. Fixed the cracks and in primer. Paint is next.
    ZZ Top Chop, OG lil E, cfmvw and 5 others like this.
  2. Rusty J
    Rusty J
    Fantastic tech. I really enjoyed the detail you put into this and showing all the steps, opens some possibilities for wheel swaps I hadn't considered.
    What did you use to fill the cracks in your wheel? I've been researching this as I've got a few to repair in the not too distant future.
    matthew mcglothin likes this.
  3. matthew mcglothin
    matthew mcglothin
    Thank you very much. As far as the cracks I use 3m panel bonding adhesive. In the body shop we use it for bonding steel, aluminum and plastic panel on newer cars. Works very well with these older cracked wheels.
    oldiron 440 likes this.
  4. Good thinking. Easier to “fix” the wheel instead of screwing with the column. You get an A+.
  5. DIYGUY
    DIYGUY
    from West, TX
    Nice job. Mechanically and editorial both.
  6. panhead_pete
    panhead_pete
    Miss tech posts like this. Thanks!
    matthew mcglothin and OG lil E like this.
  7. goldmountain
    goldmountain
    Looks good. That's a new way to get power steering.
