  1. NEW MERCH!!!!!!
    Hey guys... It's that time of the year again and we are introducing some new shirts in the Jalopy Journal store - including our first ever pocket shirt! So, if you are in the need for some new threads go here:
    The Jalopy Journal Store
    Dismiss Notice
Projects CONVERTING A 1933 FORD FOUR DOOR SEDAN INTO A 5 WINDOW
Discussion in 'Traditional Hot Rods' started by H-O-O-V-E-R, Aug 10, 2017.
  1. Babyboomerboy
    Babyboomerboy
    Wow, this is really a great build by some really skilled metal workers. Can't wait to see the next set of pictures.
    H-O-O-V-E-R likes this.
  2. H-O-O-V-E-R
    H-O-O-V-E-R
    This is what's going on up top, looking down on the roof. Lots of cutting an splicing. Do you see the factory lead spot? Had to melt it out obveosly to weld. Gonna have to re apply when the body work is closer. Had to make a relief cut in the corner, that section will take a little bit of stretching as well.
    LOOK WHAT MADE ITS WAY INTO THE SHOP! Freshly rebuilt flathead motor. So excited for this bad boy. Gonna paint the block a light gold.
    Decided to lay the unflanged roof insert in to see if the crown matched up with the roof. Sits very nicely.
    Gonna take a little more work to get all the lines to flow but off to a good start. You can see where I had to cut the corner out and slide it an inch or so to match. Almost ready to weld.
  3. H-O-O-V-E-R
    H-O-O-V-E-R
    I'll take some close ups for you, pretty simple to make.
    catdad49 likes this.
  4. 34fordjay
    34fordjay
    from Mass USA
    WOW. You are a very serious body guy. Great work.
  5. BJR
    BJR
    from Minnesota
    Is there another panel under the top louvers to deal with the water that goes into the louvers? Or is it a sunny day car? If another panel please explain how it works. You are doing an amazing job on the car.
  6. JimmyD3234
    JimmyD3234
    from PA
    LOOOKING G:D:DD :cool: :cool:
  7. Wow, when you step back you can really see just how well you’re killing it! Everything looks smooth & flowing.
  8. The37Kid
    The37Kid
    This is one of my favorite photos of the build, first photo of the Fordor, then the Coupe find with the old shovel A pillar, now the louvers. You'll bleed sanding them, but it is always worth it. Happy New Year! :)Bob
  9. Son'ofa'b#tch. The lengths people go. Incredibly tidy work, on what was surely a damned mess. Wowsers.
    H-O-O-V-E-R and Outback like this.
  10. paint-boy
    paint-boy
    from Hector, MN
    I also made a similar template tool. Agreed, very easy to make and use it more often than you’d think.
    I made mine out of:
    (2) 6’ aluminum rules (straightedges)
    Several lengths of 1” aluminum flat stock and milled the long adjusting slot in them.
    Aluminum angles (cut and welded to bottom straightedge)
    Install wingnuts on the top adjustable carriage bolts for easy adjusting. (Square holes for carriage bolts to make it a one handed adjustment when needed)
    dwollam, brEad, belair and 3 others like this.
  11. The37Kid
    The37Kid
    ^^^^^^^^^^^^ WOW! That is a great home made tool. WELCOME to the HAMB! Bob
  12. H-O-O-V-E-R
    H-O-O-V-E-R
    Love it! Project is looking sweet!
  13. H-O-O-V-E-R
    H-O-O-V-E-R
    A lot of guys do a panel underneath, I don't like the way they look so mine won't have one. Plus I live in Utah and it hardly rains. Having a panel under it seems like it would create some problems with water being trapped between the two. If I want it to be water tight I will just end up making another roof insert with no louvers. Also thanks for your support!
    brEad, jackalope and spurgeonforge like this.
  14. H-O-O-V-E-R
    H-O-O-V-E-R
    This side really wanted to fight me. Worked through it though.
    Had to make a few relief cuts.
  15. H-O-O-V-E-R
    H-O-O-V-E-R
    Cut a wedge to take out crown so it matches the other side. There was damage to this side so it needed to be readjusted. This wedge was brought together then tacked.
    IMG_8222.JPG IMG_8223.JPG IMG_8224.JPG IMG_8226.JPG IMG_8227.JPG IMG_8228.JPG IMG_8230.JPG IMG_8231.JPG IMG_8232.JPG IMG_8233.JPG IMG_8235.JPG
    Both roof sections grafted together and tacked. Starting to look like a 5 window!
  16. The37Kid
    The37Kid
    Very nicely done! Bob
    H-O-O-V-E-R and kidcampbell71 like this.
  17. chevy54man
    chevy54man
    from NC
    Wow, just incredible work. You really are magic when working with metal, best to you!
    H-O-O-V-E-R and 48fordnut like this.
  18. 34dream
    34dream
    Any good old subrails for sale? Looking for originals
  19. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    Great work,
    I bet Henry would be amazed at the lengths people go to, to drive his cars ...
  20. Amazing work!
  21. jackalope
    jackalope
  22. HOOVER, Glad to see some hot rod work being done in Chris's shop. He has such great skills and it is looking like you do also. Hope to see this there next August on our way to the salt.
  23. H-O-O-V-E-R
    H-O-O-V-E-R
    Unfortunately mine were rotted out, had to get new ones myself.
  24. H-O-O-V-E-R
    H-O-O-V-E-R
    Thank you! Can’t wait for speed week. I will be there! Look forward to seeing all the cool cars come through from back east!
    spurgeonforge likes this.
  25. sloppy jalopies
    sloppy jalopies
    how about #1034 the late Sam Samson from Maine's yellow '33 3w,
    351 / 4 sp / 9" .... 202.??? mph. I think.
  26. H-O-O-V-E-R
    H-O-O-V-E-R
    22A080F5-7014-4515-8D5A-56302B7B21CA.jpeg 4C26ABD5-1091-4E39-BD0B-C118CD8F5D7F.jpeg
    Cut out and grafted in a piece off of the sedan.
    Doing a few different renderings on the computer to get an idea of what I want.
    782F11B7-0C89-426A-8825-41E969548510.jpeg 9E023F03-E0B2-433B-B4B5-2D7969505796.jpeg
    You can see how off the quarter window is. This allows me to find the best place to cut that will match up the best.
    A pillar leaned
    AE12C78E-512F-42AC-AD59-DB5039A9E985.jpeg E43FF6D9-A646-4349-BAE8-AF2561BD50BD.jpeg
    dwollam and Nailhead A-V8 like this.
  27. H-O-O-V-E-R
    H-O-O-V-E-R
    Messing around with some looks and window heights.
    509551E4-BF32-4008-BA76-74DFA5D51F6E.jpeg FF2AB1A6-AA6A-45F5-81A8-0C5DDE0018E7.jpeg 35AA0091-12FF-487D-91B9-96CC9C1C2B8E.jpeg F3497B4A-2CDA-46CF-BA1C-B7EC9F31C342.jpeg A5AE6246-BD5A-4D55-BFA4-089CA8FC0CD2.jpeg B300C574-5A36-4F79-A312-6A09412FFA15.jpeg
  28. H-O-O-V-E-R
    H-O-O-V-E-R
    Throwback picture of my dad and I over a year ago.
  29. H-O-O-V-E-R
    H-O-O-V-E-R
    Was able to do a little more work on the Bonneville Bastard this week. First drilled out spot weld to take almost the entire A pillar out. ( only the outer structure) this way I can work on the pillar and make any adjustments while it’s off the car. It makes it easier to do so. Also paid the price for not wearing eye Protection for the slightest moment, spent the night getting metal shards drilled out of my cornea at the hospital. It all comes with the territory.
    0F74E8FB-4FC3-4E29-93D7-733C51BD637A.jpeg F8CE22AF-A5F0-466F-9620-4666FF257B05.jpeg F6C1D1D7-492D-4559-8BCF-7F120FF70F5E.jpeg 11C49D36-E97F-4BF9-8AE7-96FEA95914CF.jpeg F9324CAE-B4F4-4F4F-B0A7-6F1B53301386.jpeg B7BD2D31-A264-4BFC-AF9C-85B96069620A.jpeg 7909B4FD-82D0-4A5B-B65E-E4CA933324A1.jpeg
    Chop all layed out! I was so excited to finally get to cut the top off again after spending months putting it on.
    5D4D77D9-8CAB-4225-AF48-8B30455C2C38.jpeg 81BC3EB5-C296-4D1B-9E7C-5936CF9BAF99.jpeg B696F237-C6DE-4333-A81E-A81AEE375BCC.jpeg
    Layed the top back on to get a general look. Still need to lean the pillars.
    6DF62FDE-2D22-420E-ADA3-121881B809B8.jpeg F28992AB-2EC3-4964-A1E6-1937E7D5461F.jpeg 87345E46-83A1-4B11-B8D2-22D6AB3A1C09.jpeg 5C929B7D-CD13-4E87-967F-F73210DD9322.jpeg B0BE3041-F8A1-4258-9B3C-4D4AD9B3A101.jpeg
    She is looking pretty good. Still need to make some minor adjustments to get it looking just how I want it. Thanks for looking!
    40ragtopdown, brEad, jgrohio and 16 others like this.
