i have a 59 apache 1/2 ton. is there a bolt on hub from early car that will fit to convert to 5 lug? i have been told there is, but no one is sure what years will work. any help would be appreciated.
thanks Clay. i knew someone would know on here. are the bearings the same or do i need different ones?
49-50 won't work, you need 51-54 passenger car hubs and drums. and remove the dust shield, that thin plate that fits between the bearing and brake backing plate, use the one from the car or just leave it off.
thanks squirrel. i never tried to keep a straight axle before. would like this one stock, only with 5 lugs.
