Projects Converting 1934 Ford 4D Sedan to 3W Coupe
Discussion in 'Traditional Hot Rods' started by Kontra, Oct 30, 2022.
  1. coupeman36
    coupeman36
    Great job!
    Kontra likes this.
  2. Fitnessguy
    Fitnessguy
    Finished product looks great. Huge respect for big body transformations like that.
    Kontra likes this.
  3. redoxide
    redoxide
    from Scotland
    Brave colour choice but it worked in the end .. looks great . Brilliant job making something from nothing ; Turned out looking just swell :)
    Kontra likes this.
  4. fleetside66
    fleetside66
    Very impressive....where there's a will, there's a way.
    Kontra likes this.
  5. Outback
    Outback
    from NE Vic
    What a great story & lovely car! I love the way you toned down the bright colour, it's perfect!
    Kontra likes this.
  6. Kontra
    Kontra
    from Finland
    Thanks all the nice comments!
    I appreciate it :)
    After the Tampere Hot Rod & Rock Show in April 2022 there was another show in May. I organized Primer Magazine 20-years Anniversary Show in my hometown Karkkila, Finland.
    After all shows I booked time for engine tune up.
    My friend owns older roller dynamometer and idea was to to tune up AFR (Air Fuel Ratio) as good as possible. AFR was quite good with stock jets and timing. There was some mystique problem in the 21-stud. Sometimes it drops 1 or 2 cylinders off. Weirdest thing that it could be whatever cylinder. I have a new Stromberg e-Fire, new plug wires, new plugs, new fuel pump, new alternator… We didnt find what was the problem….
    After the engine tune up I drove the car to trailer and towed it to another friends garage to do 3D wheel aligment. That is a thing that you should do every car!!
    I was bored this engine problem. I couldn't find the reason!! Car sit about one month and didn't touch it at all!
    There was still some electrical work to do and it took almost rest of the summer.
    When electrics were done I did some test drive in the roads first time! Great feeling!!
    At the end of the August car passed registration procedure! Finally I had a pleasure to bolt Finnish plates on it!!
    There is still some issues on the 21 stud and clutch is slipping. So enough work to do in this winter!
    Best regards
    Ari Berghäll
    Päätoimittaja/Editor in chief
    PRIMER MAGAZINE
    www.primermagazine.fi
    www.facebook.com/Primerlehti
    www.instagram.com/primer_magazine/
    https://www.youtube.com/@primer_magazine
  7. Squablow
    Squablow
    I have one of those Stromberg distributors on my T roadster and I had running issues with it too, not sure if you ever got yours solved, but my issue was my generator quit charging, and the Stromberg distributor needs to have at least 6.5 volts to run properly, it would start and run with just the battery but it ran poorly. Once I got my generator working properly again, all of my distributor issues went away. Now it start easy and runs great through the RPM range.
    Outback and Kontra like this.
  8. tippa77
    tippa77
    from Finland
    Hi Ari
    Look at FordBarn there is discussion about Stromberg e-fire. I also bought it to my 39 coupe and i have some issues with it
    Arska
  9. BILL LUPIANO
    BILL LUPIANO
    from Canada
    Looks great Ari!Congrats!!
    Kontra likes this.
  10. Straight Axle Guy
    Straight Axle Guy
    Great job, congrats!!!
    Kontra likes this.
  11. Kontra
    Kontra
    from Finland
    Thanks for all the comments! Very glad to read all the compliments!! :)
    About the engine "not running perfect"-case:
    I got a new e-Fire from Clive at Stromberg. That doesn't change a thing at all. I also tried with new plugs (32 pieces), different gap in the plugs, another new set of plug wires. I add extra ground cable from distributor to chassis. I add a fuel pressure regulator.... everything.
    I try to post a video here somehow how it runs...
    Best regards
    Ari Berghäll
    PRIMER MAGAZINE
  12. Squablow
    Squablow
    Start it up and test to see if your generator is charging. If it's not making at least 6.5 volts, the distributor won't work. Easy thing to check, get that out of the way first. That was my problem.
    Kontra likes this.
  13. the oil soup
    the oil soup
    from Tucson,AZ
    The patina looks super and car came out great!
    Kontra likes this.
  14. Kontra
    Kontra
    from Finland
  15. j hansen
    j hansen
    Learned a new sentence in Finnish:D
    Outback and impala4speed like this.
  16. A lot of really nice work here - now drive the wheels off of it! Congrats!
    Kontra likes this.
  17. micshotrodgarage
    micshotrodgarage
    from colorado
    Love the work you have done, Inspiration for us all! What's your next build? looking forward to more from you ; Cheers.
    Kontra likes this.
  18. panhead_pete
    panhead_pete
    Love the look of an undropped axle on a 33/34!
    Kontra likes this.
  19. Kontra
    Kontra
    from Finland
    Thanks for the all compliments and nice words!!
    I promised that I won't start as big project ever!
    My A-Coupe was total "puzzle" when I bought it November 2007.
    Terrible work to build a car for this crap
    This '34 project was even worst puzzle than a A-Coupe!
    There has been few dream cars on my mind something like +25 years:
    A-Coupe (DONE)
    '33-34 Coupe (DONE)
    '48 Chevy (DONE)
    This time I decided to go the easiest way and in June 2022 I bought ´48 Chevy Kustom.
    Best regards
    Ari Berghäll
    PRIMER MAGAZINE
    Outback, Kreepea_1, ss34coupe and 3 others like this.
