Technical compressions ratio question and is this a deal?
Discussion in 'The Hokey Ass Message Board' started by 64 SS, Jun 24, 2015.
  1. 64 SS
    64 SS
  2. draggin'GTO
    draggin'GTO
    Depends on the size of the engine in question.
  3. gimpyshotrods
    gimpyshotrods
    10cc's are roughly 1-point of compression on a 4" bore SBC.
    You will need a second key on the crank.
  4. 64 SS
    64 SS
    Motor and parts are in the craigslist link.
  5. 64 SS
    64 SS
    Yes second key is a must. I am just starting from scratch on the motor so wasn't sure if u should scoop this up.
  6. 64 SS
    64 SS
    I thought 500 bucks for everything might be a good deal.
  7. squirrel
    It might work for what you want to do. Or it might be better to set it up with dished pistons. Kind of depends on what boost, what fuel, what heads you plan to run.
  8. draggin'GTO
    draggin'GTO
    Sorry, didn't see the link.
    Try using this compression ratio calculator, it's on a Pontiac site but it of course works for any brand engine:http://www.wallaceracing.com/cr_test2.php
  9. 64 SS
    64 SS
    It will be a street car 100% of the time,93 0ctane pump fuel and aluminum heads. Today was the first day I actually started looking at parts.
  10. blowby
    blowby
    from Nicasio Ca
  11. 64 SS
    64 SS
    2 bolt. If I do get a 2 bolt, I will get it machined for 4 bolt splayed caps.
  12. 64 SS
    64 SS
    Its says CR is 1.40 am I missing something? Haha
  13. squirrel
    maybe you put in the wrong numbers? this is what I got with some rough numbers.
    Your displacement is 355.12 CID
    The Compression Ratio is: 10.17
    64 SS likes this.
  14. 64 SS
    64 SS
    Yea man, thats not going to get it. I will just put together a parts list and do it right. I just purchased a book called street supercharging by pat Ganahl, I will start reading it tomorrow. Im sure I will be back around with more questions haha. Thanks for the help.
  15. gimpyshotrods
    gimpyshotrods
    Yeah, about 250psi of boost.
    64 SS likes this.
  16. joel
    joel
    With that collection of parts, you should be at 9.05;1 static CR.
    64 SS likes this.
  17. What a cool chart! I was wondering what mine is with huge-chamber heads and pop-up pistons...came out to 9.52. That's liveable.
    64 SS likes this.
  18. 56sedandelivery
    56sedandelivery
    Block and pistons only? Could be a good price, especially if you use a thick head gasket and 76cc chamber heads; could be 8.5 or lower.. Those are some deep valve pockets in those pistons. Need a forged aftermarket crank I'm not going to use. The CH height on those pistons are with a 6 inch long rod, another few $$$. I am Butch/56sedandelivery.
    64 SS likes this.
  19. 64 SS
    64 SS
    Comes with block, pistons, studs, stand,dual plane edelbrock intake, factory crank and fly wheel.
