I completely went through my column drop/lock/ign. assembly. Before I put it together I am assuming that the mover parts like the column lock sider, and switch it's self as well as the end of the key need to be lubed? Should these parts be approached as a lock? Where you use only graphite powder as a lube? Or should some of these parts need some lithium type grease?
