I have a Coats 1001 Tire Balancing machine for sale. I purchased this unit along with some other equipment from a shop that had closed. I unfortunately do not have the power to run this, so I must sell. I was told that it was in good working condition when removed, but I do not have the power to test it. Machine is used, and shows some normal wear, but is in overall very nice shape. Price Reduced... $500 takes it! Here is a link to the User Manual: http://www.nytechsupply.com/downloa...ration_manual/Coats_1001_Operation_Manual.pdf Model 8621000 • 220 VAC • 20 AMPS • 60 Hz • 3 Phase • Single spin dynamic/static, twin plane. • Vertical wheel mounting. • Accuracy ± 0.1 ounce (or ± 3 gram). • Exclusive direct drive system (no belt - no pulleys). • Forced air cooling. • Cycle time - 4 1/2 seconds (standard tire). • Rim diameter 10-17 inches. • Fully interlocked ABS guard hood (safety feature). • Maximum tire diameter 42 inches. • Approx Weight 650 lbs. • Few moving parts. • Large dials for data entry. • "No bolt down" installation. • Static/mag feature. • Large readout in 1/4 ounce or 1/10 ounce or gram increments. • Greater distance from shaft to machine (better for front wheel drive application). • 1 1/2 H.P. modified torque motor: Large housing for heat dissipation. Motor insulation - heavy duty for high temperature application. Motor rated for 900 RPM use. • Oversized weight bins. • Standard adapters fit. • Removable shaft for closed-center wheels. • Control panel positioned for best visibility. • Easy to read position lights. • Scratch resistant surface. • On-Off switch. • Electronics isolated from motor heat. • Simple calibration. • Strategically numbered dials for easy reading.
