I have my BBC and the BW super T10 tranny with a blow proof bellhousing , now i need to choose a clutch set up. This is going in my 31 Ford Coupe, i want to run a hydraulic clutch set up . I doubt i have room under the floor so i may go with the fire wall mount or another type set up. Was hoping to get some inputs on this from others that have done the same . Pros / Cons etc...... What brand cutch did you go with also the hydraulic throwout bearing. Pics and thoughts would be great , thanks . Chris
I put a Luk-Schaeffer clutch kit in my 464 BBC ahead of my Super T10. It's seen some hard drag use, plus street miles, and I'm very happy with it. Total cost was less than $120. I ordered the kit for a 1970 454 Chevelle, as they have a higher pressure plate rating. Mine is mechanical Z bar, so can't comment on the hydraulic setup.
