Technical Clutch fluid
Discussion in 'The Hokey Ass Message Board' started by coilover, Aug 5, 2021.
  1. coilover
    coilover
    from Texas
    Have a Hudson with a 3sp OD trans that has the wet clutch. Can buy the "Hudsonite" clutch fluid but if there is a modern fluid readily available at any parts store would rather go that route.
  2. leon bee
    leon bee
    Many Hudson guys say Dex III is okay.
    squirrel likes this.
  3. PacaRacer50
    PacaRacer50
    Contact Doug Wildrick at Wildrick Rubber Products at www.wrphet.com
    Trust me when I say he has everything for a Hudson that you may need.
    First Class Hudson nut to be sure.
  4. squirrel
    ATF for older transmissions works. If it's leaking, you're probably going to end up replacing the clutch and TO bearing anyways in the near future. Just don't let it get dry, and it'll keep going for a while.
