I'm putting a clutch cover and clutch disc on the flywheel today. The bolts are 3/8ths grade eight fine thread . I plan on the tourque at 25 pounds. They have the right lock washers but I'm wondering if I should use some blue thread locker?
Here at my shop I always use locktite on pressure plate bolts and flywheel bolts even if they have lockwashers. I have never had any problems with bolts coming loose.
The proper Pressure plate bolts will have a 1/4 shoulder under the threads,,,in other words,the threads do not go all the way up to the bottom of the head
