Hot Rods Cloth covered spark plug wire
Discussion in 'The Hokey Ass Message Board' started by Shamus, Apr 23, 2015.
  1. Shamus
    Shamus
    from NC
    image.jpg Finally found wire tha will work with a HEI distributor. 7.8 mm from brillman.com. With a little effort & patience it will go thru the Speedway looms for a flathead Ford/Merc
  2. ^^^ it sure does !!! ^^
    Is that an air conditioning line in the lower right ? Who knew ? Flatheadwith AC ... hmmm ... nice.
  3. Atwater Mike
    Atwater Mike
    A/C on a flathead? Shameless. (sorry, couldn't resist...) Beautiful wire & loom work! Love those Raja terminals...
    mgtstumpy likes this.
  4. 54vicky
    54vicky
    excuse the slobber
  5. dan c
    dan c
    i checked out the brillman web site--lots of interesting stuff. used to run "super rajahs" in the '60s and they worked great--brillman has them. Scan0005.jpg
  6. harpo1313
    harpo1313
    from wareham,ma
    Nice and clean ,thanks for the link.
  7. The 39 guy
    The 39 guy
    Shamus that is nice looking set of wires! I am glad you posted this today. I just discovered that I need to replace my fancy see through red wires with some resistor wires so that my tach will function correctly. Thanks for posting the Brillman site.
  8. Shamus
    Shamus
    from NC
    [QUOTE[​IMG]="Atwater Mike, post: 10956690, member: 723"]A/C on a flathead? Shameless. (sorry, couldn't resist...) Beautiful wire & loom work! Love those Raja terminals...[/QUOTE[​IMG]]
    Most don't notice , Jack & Daniel did a great job[​IMG] at hiding most of it!! - would it be even more shameless if I IMG_5517.JPG get-attachment.aspx.jpeg told U it also has heated seats?? At 73 my old body gets hot & cold!!!
  9. Boxcar's 1928
    Boxcar's 1928
    Is the dryer in there as well as the lines....very nice details
    kidcampbell71 and Texas Webb like this.
  10. tubman
    tubman
    I have found that careful routing of the tach signal wire from the distributor (way around the fenders, and NOT anywhere near the engine) will eliminate that problem.
    It's worth a try.
