Clipping a 41 pontiac sedan?
Discussion in 'The Hokey Ass Message Board' started by jordabennett, Feb 14, 2013.
  1. Hey guys. has anyone here clipped a 41 pontiac sedan and used a 68/69 camaro clip?
    any info would be greatly appreciated! thanks again!
    jordan.
  2. 40Standard
    40Standard
    from Indy
    probably the same as doing a 41 Chevy. do a search on here
  3. 55chieftain
    55chieftain
    No, but I would agree to use a rear steer clip like what you have if I was doing it. 67-69 f-body and 68-74 x-body Nova is similar. Plus they are narrower than the newer f-body clips as well.
  4. I put a Nova clip into a 40 Olds coupe and it was the cats ass!
  5. yeah lucked out and thats what we have is a 68/69. just trying to see and pictures or any insight.:D
  6. ...did one years ago, easiest one I've done...the Pontiac frame is different that the Chevy, it's channel design with an X-member, when you cut the frame you can slide the rear subframe arms rite into the Pontiac frame, works out great. Will see if I can dig up the pics...
  7. that would be awesome! thanks again
