Projects Cleaning backside of aluminum wheels
Discussion in 'The Hokey Ass Message Board' started by Edd, Jan 3, 2025.
  1. Edd
    Edd
    Have a couple of (split) aluminum wheels that I would like to use, the backings have a black crust on them possibly from years of road tar.
    Been spot testing with lacquer thinner, oven cleaner, paint remover, Goo Gone, Acetone, none of them appear to be effective.
    Have any homebrew recommendations?
    Thanks
    chevy57dude likes this.
  2. squirrel
    I think Super Tricks are off topic here...but I just scrub them with Dawn, and put them back on the road to get dirty again.
  3. Edd
    Edd
    Thanks...a simple I don't know would have worked:)
    swade41 likes this.
  4. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    This stuff works well on brake dust and grime. On the backsides of wheels, I let it soak in and scrub with a stiff brush. Keep it wet, wash off with water.
  5. Edd
    Edd
    Thanks...I see Oreilly Auto has "bug and tar" remover...may try both of them.
  6. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Don`t get bleach white on the shiny part, it'll ruin it.
    Edd likes this.
  7. Happydaze
    Happydaze
    Cleaning the backside? Bidet?
    Chris
  8. Edd
    Edd
  9. Budget36
    Budget36
    Blasting cabinet would work.
    '34 Ratrod and 2OLD2FAST like this.
  10. Blue Moon Garage
    Blue Moon Garage
  11. Bandit Billy
    Bandit Billy
    My daily has Emmitts (22's) on it and the back of the wheels are visible so every spring I clean and detail them. I find WD-40 will cut through the road tar if it is sets for a bit and it doesn't mar the polished aluminum on the front. Then a cursory coat of mothers or Flitz with a Flitz ball.
    Magfiend, mad mikey, SS327 and 3 others like this.
  12. SS327
    SS327
    High pressure, pressure wash. Take them to some place that steam cleans truck engines.
    Truckdoctor Andy and Edd like this.
  13. Old-school elbow grease :eek: and a wire brush . Then the fancy stuff.
  14. '29 Gizmo
    '29 Gizmo
    from UK
    If you want it super clean then oven cleaner (diluted sodium hydroxide). But don't get any on the decorative surface.
    Edd likes this.
  15. ALLDONE
    ALLDONE
    I use alumibrite... it's used to clean aluminum before you weld....also there's a cleaner that boat detailers use to clean pontoons that have been sitting in the water at marina's... best to put it on with a brush... you have to make sure you rinse it well with hose water and brush it when you rinse... makes aluminum look brand new... then there a stuff called shark hide that you can brush on that keeps them looking new... I have some out back, come by and I'll help you...
    SS327 and Edd like this.
  16. ALLDONE
    ALLDONE
    also, I would gorilla tape over the lug hole before you start,
    catdad49 and Edd like this.
  17. ALLDONE
    ALLDONE
  18. TA DAD
    TA DAD
    from NC
    Taking them apart would make it a lot easier , The center piece where the lugs go is separate ( may be cracked , they often where ) and you can just reseal them with silicon . It has been decades but I have polished a few in a past life and you had to disassemble them and have the bolts chromed.
  19. TA DAD
    TA DAD
    from NC
    So I would take them apart and put them in the parts washer with varisol and a Scotch brite pad and go from there.
  20. indyjps
    indyjps
    Goop hand cleaner is a good start, won't mess up aluminum and if the goo is petroleum based it will start breaking it down.
    I actually use it on daily driver paint to soften bug and grease during washing wax. Screenshot_20180510-194144.jpg
