I used to work in a small fabrication shop with a guy that had a well earned reputation for his clean routing of wires & hoses. There was 3 guys that all did the same type work, but you could always tell which jobs Jay did. Im looking to apply this same super-neat look to my plug wires. I'm sure there's a bunch of you out there, that have put some serious thought into making your engines look clean. Let's see what you got. Post some pics!
I ran my plug wire under the exhaust manifold, to the rear of the engine, and up to the distributer. I'm running a SBC with ram's horn manifolds, other engine types might not work as well. What is your engine/car?
'56 Olds 324, fresh chrome on original dimpled covers, repop early painted wire separators notched to fit covers, straight boot 8mm Taylor wires, Vertex magneto..
The cleanest plumbing and wiring jobs are the ones that are hardest to see. They blend in, don't call attention, hid in plain sight.
I have the same situation as 57heap but be sure to use wire seperators as you don't want anything to touch anything...............
Paul, that's a beautiful engine, but is cross-fire an issue, with your wires zip-tied so close together?
Looks very tidy, what are the nice plug connections? Just a little nicer than the basic rajh (sp) ends.
Thanks, no I've never had a crossfire issue running like that, good wires and good juice will take the path of least resistance and stay in the wire.
