Technical Choosing Bead roller dies
Discussion in 'The Hokey Ass Message Board' started by flatnasty, Mar 20, 2014.
  1. flatnasty
    flatnasty
    from Vancouver
    Ive got to build a floor for my 34 http://www.jalopyjournal.com/forum/showthread.php?t=857397
    I'm planning on buying a bead roller to do it but I'm not sure the best choise of dies. They are expensive and I don't want to buy dies that I wont use.
    What are the STAPLE few sets of die's you guys use around your shops?
    Thanks Brad
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    We have 1/4, 3/8, and 1/2 inch round dies and seem to use the 1/2 most, especially for the type of things you are describing. We use that one a lot more than the other two.
    Don
  3. flatnasty
    flatnasty
    from Vancouver
    Hotrodprimer
    I am planning on buying a Baileigh unit but I was going to get power fed one and it doesn't look like it comes with die's which is why I was wondering what the staple Dies to get were.
    Brad
  4. rob bob
    rob bob
    from Canyon TX
    I don't know if the dies are interchangeable with the unit your buying but you might just buy a bead roller from HF an use the dies.
  5. metalman
    metalman
    Not familer with Baileigh selection, I use and love my Mittler's. Besides the round (I use a 1/4", mostly on race car tin, and a 5/8 for early Ford stuff), a step die is a must have, especially on floors. The other dies I use all the time is a tipping die and a tank roll. We also make our own, often they don't make one to do exactly what I want.
  6. jw johnston
    jw johnston
    I have a mitler brothers bead roller and I use a 7/8 die most of the time on early cars into the 40s . It was the biggest one they could supply me off the shelf at the time. They will make bigger ones to order but I think any bigger and it would have a hard time with 16 and 18 gauge. 1/2 and 1/4 also come in handy in a few places on early cars but manly on later cars id say 50s and up.
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    If your building floors, and their usually built from 16 gage or thicker, you'd want the 1/2'' or bigger. The 1/4 '' & 3/8'' would probably be of some utility for '' decrative '' work, but not for use on a ''real'' floor panel.
    There are some tough choices of what machines to buy out there, today! Baighly (sp) & Mitners (sp) both make good products!:)
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    We have a ProTools motorized roller and it has worked great for over 8 years and lots of beads. A while back I built a flat table for it to support the work (with lots of helpful suggestions from HAMBers) and that makes it a one man operation now.
    Don
  9. In my humble oppinion, as I own a HF roller and have done the much needed structure up grade myself, added a steering wheel adaptor (a big help, but still a 2 person affair) and finally a power motor, great! But I am still stuck with a 18" throat, and limted dies, I do have the HAMB tipping die, really a MUST! BUT! In retrospect my advice is this, you doing one car? Got friends to help? A HF is okay....and it will match your beginning skills, myseld included. But if I were to only know after doing several cars, I would buy a Baleigh or HD36" MB, they do offer a myriad of dies. Good Luck!
  10. alchemy
    alchemy
    I use the offset die more than anything. I think it's an 1/8 inch. If you can only buy one, buy a 1/4 inch and then you only clamp it down part way to get a nice soft 1/8 inch offset.
  11. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  12. Don,
    I am sure that table makes the roller much, much more user friendly.
  13. flatnasty
    flatnasty
    from Vancouver
    Alchemy
    When you say "offset die" is that the same as a "step die" ?
    Brad
  14. flatnasty
    flatnasty
    from Vancouver
    Thanks Everyone for your great input!
  15. alchemy
    alchemy
    Probably. Just basically a step down. By adjusting the pressure, and even moving one of the dies outward a little more than it should, I can make the shape quite different.
