Chevy Split Manifold Help
Discussion in 'The Hokey Ass Message Board' started by 41FordVert, Oct 13, 2015.
  1. 41FordVert
    41FordVert
    Got this from a friend. It has the added piece in front of the original collector. Front 2 ports are blocked before the carb. Going on a '53 Chevy truck. Just never saw one split this way before. I see most split behind the original exhaust outlet. ImageUploadedByH.A.M.B.1444789911.082450.jpg ImageUploadedByH.A.M.B.1444789930.548675.jpg Thanks for your response.
  2. 54fierro
    54fierro
    from san diego
    I have seen a couple of those, though never mounted. As long as you can get the exhaust routed without hitting any steering, side motor mounts or alternator/generator it should sound and work like a manifold split at the rear.
    I'm not too familiar with the trucks but that wouldnt clear on my car
  3. High5
    High5
    As 54fierro stated, most splits were made to the rear for clearance to the steering and generator. Until you mount it on the truck, you really won't know. The sound would be the same whether it's forward or to the rear.
  4. 302GMC
    302GMC
    from Idaho
    The earlier the car, the more often they were seen. In your case, I'd trim the dual side pipe & weld on a flange at the same level so as to match the stocker.
  5. bowtie56jw
    bowtie56jw
    mine on my 57 chevy is added to the front and just clears the gen. love the sound of a split bolt.
