Technical Chevy interior door release handles?
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Sep 24, 2024.
  1. I have to replace the door relay and handle on a 54 truck because they are both stripped out. This has the handles with the screw which kept loosening up, necessitating said replacement. Can I use the passenger car door release handle with the clips instead??
  2. Don’t think so. Get you some correct length set screws with an Allen head. A 1/4 inch socket with the correct Allen on an extension should allow you to put good torque on the set screw. My opinion
    302GMC likes this.
  3. those use a setscrew to tighten the handle, then another screw to lock the set screw in place.
