i have a 69 chevy 307 it has a 168 tooth std shift flywheel i have an adaptor for an early ford trans the adpt. has a three bolt hole for an early chevy starter what size starter drive do i need how maney teeth the drive i have don,t mesh with the flywheel thanks [email protected]
if you want to bolt the starter to the adapter , i believe you need the one for the late 50s turboglide if you want to bolt the starter to the engine block , you need the common staggered starter
You will need a 153 tooth flywheel and an early starter. Starter canstill be had from NAPA - used on lots of agricultural machines for years after chevy went to the block mounted starter
I get my starters from Autozone for the small block in my Willys, it is the same 3 bolt starter that was on my '65 C-10.
No need to change flywheel. 168 tooth will work. Go to Napa and look for early Chevy bull nose mount starter. 55 to 57???
i believe the starter i was talking about in my first post uses a 14" flywheel correct me if i'm wrong
