Technical Chevy distributor
Discussion in 'The Hokey Ass Message Board' started by 46poncho, Jan 12, 2020.
  1. 46poncho
    46poncho
    from Indiana
    Here I am back for more education. What is the difference between a 350 and 305 distributor? A friend gave me a distributor from a 350, I was going to install it today and the drive gear was too big to go through the hole in the block. I thought they were interchangeable???
    Thanks
    Scott
    Sent from my SM-S367VL using The H.A.M.B. mobile app
  2. The Magic Ratchet
    The Magic Ratchet
    The same distributor should fit in either a 305 or a 350. I'm not sure if you even have a Chevy distributor.
    Lou
  3. Got pictures of the distributor?
    46poncho likes this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, the only v8 chev distributors that are different are 348 and 409.... even a big block 396 - 454 distributors will fit a small block
    ted kovacs, VANDENPLAS and 46poncho like this.
  5. 46poncho
    46poncho
    from Indiana
    It is not a long shaft distributor, it looks more like a Pontiac to me.
  6. 46poncho
    46poncho
    from Indiana
    Take some pics tomorrow.
  7. studebakerjoe
    studebakerjoe
    46 Poncho, are you sure it was the gear stopping it? There are big block distributors that are longer which were used on the 366+427 truck tall deck engines. They look like other distributors but are about 1/4 inch longer.
    ted kovacs likes this.
  8. 46poncho
    46poncho
    from Indiana
    Yep, gear would not fit. It is a very short distributor like a Pontiac. I was going on what I was told, that it was a 350
  9. squirrel
    Pontiac, Buick, and Oldsmobile each made their own version of the 350 engine, and they're all different from the Chevy.
    But without pics, we can only make wild guesses.
  10. Sounds like you got a Pontiac 350 Distributor.
  11. 46poncho
    46poncho
    from Indiana
  12. Says Jim, as he throws his hands up in the air...:D
    squirrel likes this.
  13. 46poncho
    46poncho
    from Indiana
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    that is a pontiac dist
  15. saltflats
    saltflats
    from Missouri
    With two pigtails it wasn't going to work in any small block we talk about here.
    427 sleeper and Moriarity like this.
  16. It's an Olds distributor...Similar looking to a Pontiac but notice the O-ring that Olds used.
    Rich S. likes this.
  17. Rich S.
    Rich S.
    Olds...Buick used a o-ring also , but the Buick shaft is a little longer
  18. sdluck
    sdluck
    Looks all computer controlled electronic
    Mark Yac likes this.
  19. Correct..Notice lack of vacuum advance.
    O/P, what are you going to do with that thing? Your friend didn't give you much.
