Hey guys, I'm thinking of a 3 spd for my 40 chevy truck. Looking at the trans and shifter location ,I know it is mounted near the end of the tailshaft. This will put the shifter in the middle of the seat. Is there a different way to mount the shifter forward on the transmission? I looked at JEGS and Summit, but didn't find anything. I believe the trans is a Saginaw. Any ideas will be appreciated.....
Thanks for the picture, Not sure what shifter is on it now. Your set-up looks like it will work. Are all Hurst shifters like this?
Well thats an old one,,the hardware is Syncro - loc 3 speed.. and its using a Mystery shifter..The Mystery Shifter brackets are a bit shorter and ten to mount shifter further forward.. Heres the Syncro-loc set up The Hurst Indy Shifters and the like are NOTHING like this,,and are junk and should be avoided
I had the same problem w/model a, shifter under the right leg!! I looked at a lot differnt things, to get the shifter in the center of the floor..I have "new old stock hurst shifters in the box" simple bracket redo to move the shifter forword also moves shifter closer to the leg.......I made my own shifter from a '76 vega. these GM shifters mounted on the tunnel not the trans, and in the center....so.. the "ears" are built to the left to line up w/ gear box...very simple brackets mount to the trans,mounting far forward as possible!!!! shorten/rebend rods!! now weld/ drill/ cut 2 hole bracket to hold hurst handle.. add a little "spring" to hold shifter to the right...WORKS!!!!! total cost..nothing
Is the syncro-loc hardware still available? I'm not really "up" on shifters ,as on my last one I wimped out and used a turbo 350.
They 'may' still have it,,if not look on ebay lots of used ones,,I have 1 used set up if you decide to go that route Hurst actually made a tunnel mount,,interesting looking animal
I have one on my sag 4 speed that is mounted just behind the case, I was told it is stock for a 66 gto/lemans. All I know is it sits perfect. I will also add the top mounted t5 shifter was even more perfect in my car.
I see Jegs lists a Indy SSA universal 3spd shifter, part # 530-501-0002 with adjustable stick positions. Is one to be avoided?
