Chevy 327 overheating help
Discussion in 'The Hokey Ass Message Board' started by 63bluenova, May 17, 2014.
  1. rtomss
    rtomss
    Take the cap off and let it warm up for a bit. Could be a air pocket that's restricting flow.
  2. OFT
    OFT
    Yes, a Spal 16".
    I run a sense wire from the gauge to a Dakota Digital fan controller. That is a high impedance circuit so it is not a problem. Motor is a 350" with 177" blower. Gauge gave same false reading with 396 and blower.
  3. I just went through this with my wagon. It got hot sitting in traffic but was fine while driving. Make sure the fan is pulling air through the radiator towards the engine. If it's blowing out through the grill shell it's backward (unintentionally tested this theory the other day). In my situation it was the timing being badly off. I set the timing, retuned the carb, and moved the vacuum advance to the manifold vacuum port on the carb. Runs great and 190 in traffic on a hot day.
  4. 63bluenova
    63bluenova
    Just started it with cap off and lots of air came out fan came on about 185 and temp peeked out at 195 then dropped thermostat didnot open much then closed . Hope this fixed the problem
  5. 63bluenova
    63bluenova
    How many cmf's does the spal 16 fan ?
  6. OFT
    OFT
  7. c57heaven
    c57heaven
    I too was going to suggest checking the timing. Make sure your harmonic balancer and timing marks are cohesive.
  8. Commish
    Commish
    from NW Ok
    No, don't change to a 160, won't make it run any cooler. Rating on a thermostat is just a set point that makes the engine come up to that temperature before it opens completely. After that it is condition of cooling system and capacity that determines how cool you are going to get it to run. As has already been stated there is a lot of BS info distributed along with the good on forums like this.
  9. txturbo
    txturbo
    Changing to a 160 degree thermostat will not change anything, except it will open sooner when warming up. If you are already running at a temp higher than the opening temp of the thermostat , how is that going to change anything? Only way it will make a difference is if your cooling system is capable of actually cooling it down to a temp below the opening temp of the thermostat. I would check your radiator for cold spots even though it is new. If you didn't start off with a clean cooling system when you put the new radiator in it could have a bunch of crud from the block starting to clog it up. Touch the center of the radiator core with your hand and see if it's hot or cold.
  10. 63bluenova
    63bluenova
    So far driving and letting it idle in driveway goes to 195 then back down so I think it's fixed . Thanks guys for all the help
  11. My biggest enemy on SBC engines has been "Air Pockets"
    Burp it and burp it again, run a 160 or a 180 degree thermostat and maybe burp it once more. Solved my issues.
    Shroud is a definite item also.
  12. Jay Tyrrell
    Jay Tyrrell
    Those electric fans usually have a shroud built into them. I think you mostlikely fixed it with burping the system.
    Jay
  13. 5Wcoupe
    5Wcoupe
    from L.A., Ca.
    Do yourself a favor and check distributer vacuum advance and timing
    Finally did new Vac advance on my 327 and has run 10-15 cooler ever since
