Technical Chevy 327 crankshaft question can not find a flywheel that fits! HELP!!!!
Discussion in 'Traditional Hot Rods' started by Bryan Andrews, Jun 13, 2021.
  1. Bryan Andrews
    Bryan Andrews
    So I bought a shortblock. Everything was going well. Built everything put her together and then go to put the flywheel on... doesn't fit. Tried other flywheels they don't fit either. It's like the bolt holes are just ever so slightly off a 16th to an 8th of an inch. The from my little knowledge and research the crank I have in it currently is a small journal 327 crank. Gm 4577 based on the 2 notch flange it assume it was a 65-67 forged crank. (I'm no guru so I could be wrong.) To my understanding any early sbc flywheel should fit, yet here we are. Even tried a later model truck flywheel. Nothing will work. I am lost and no one I know can seem to give me any help, so I'm hoping for some old knowledge here. Wtf is going on? I just want my car to run again.
    Deuces likes this.
  2. Roothawg
    Roothawg
    The are all the same, to my knowledge. That’s odd. I’ll be following this to see the conclusion.
    @squirrel, front desk please.
    1949*john, 31hotrodguy and Deuces like this.
  3. squirrel
    pictures? Of the crank and the flywheel.
  4. Bryan Andrews
    Bryan Andrews
    Can do... gimme 2 mins
  5. Bryan Andrews
    Bryan Andrews
    loudbang and 31hotrodguy like this.
  6. squirrel
    you don't have any old Chevy flywheels or flexplates laying around to try on the crank, do you?
    I'd suspect that imported new flywheel....
  7. SS327
    SS327
    It may sound stupid,but have you tried rotating the flywheel to the next spot to see if that helps bolt alignment.
    probird, Joe Travers, Deuces and 3 others like this.
  8. Bryan Andrews
    Bryan Andrews
    I have the one off the 68' 350 that was in it. Had the same issue. And yes I agree that flywheel is shit but I've been just playing guess and check.
  9. Bryan Andrews
    Bryan Andrews
    Yeah, no such luck
  10. squirrel
    Huh. I don't know what could be wrong.
    31hotrodguy and 1Nimrod like this.
  11. Oilguy
    Oilguy
    Do you have a buddy who could drop by another flywheel or flexplate and see if that will fit? The crank flange and casting number all look good and correct. Weird!
    Deuces likes this.
  12. OK we got photo's thanks to Jim asking. Can you supply us with measurements of both crank flange and flywheel?
    1Nimrod likes this.
  13. landseaandair
    landseaandair
    from phoenix
    Bizarre, I've had a bunch of small journal motors and any two piece seal flywheel should bolt up to it. Is it the diameter or an odd spacing on the pattern?
  14. "Determine the flywheel-flange bolt pattern. These are the bolt holes found around the center of the flywheel. According to GM Parts Direct, 1955 to 1985 small-block Chevrolet flywheels have a 3.58-inch bolt pattern, whereas 1986 and later flywheels have a 3-inch bolt pattern. Determine the bolt pattern by measuring the distance between the bolt holes. Some 350 cubic-inch and smaller engine-flywheels have bolt holes to accommodate both patterns"
    1Nimrod likes this.
  15. B.A.KING
    B.A.KING
    Could someone broke or stripped hole in crank and weld up and drilled it wrong? I've never heard this one before??
    1949*john likes this.
  16. 97
    97
  17. Are you sure the 350 is a '68? Any chance it is a later one-piece seal block IN a 1968 vehicle?
    If the "68 350" isn't actually an earlier engine and you matched that pattern to the new flywheel ....
    Got a part number off the new flywheel? (which may mean nothing if they packaged it wrong).
    Johnny Gee likes this.
  18. Well,,,,,it’s obvious from looking at the flange,,,,,it has had a flywheel bolted on before.
    So,,,,it can’t be the crank.
    Yes,,,it looks like a small journal crank flange,,,,,so,,,,that means any old model two piece rear main seal flywheel should fit .
    Are you trying to bolt it on with the engine still mounted to the engine stand ?
    The crank has the hole for the alignment dowel,,,,so it is pretty obvious where to mount the pattern on the flywheel.
    Have you tried starting the bolts without the flywheel,,,,,it wouldn’t be the first time the incorrect bolts had been tried ?
    Believe me,,,,it’s easy to get mixed up on starting a bolt pattern .
    Let us know what happens please .
    Tommy
    Deuces likes this.
  19. Bob Lowry
    Bob Lowry
  20. Budget36
    Budget36
    From my view it appears the dowel in the crank is not there.
  21. Double and triple check this ^
  22. gary macdonald
    gary macdonald
    Have you fixed it yet ? Ill go out and take a pic of the same forging crank.
    Ive never had an issue, nor do I think the crank has been messed with .
    Your engine looks typical small journal sbc . Small rod nuts , oil filter adapter etc .
    Let me know if you want a pic of the crank end .
    Gary MacDonald
    Deuces likes this.
  23. I'd be interested to know if he's trying to install it on the engine stand ... I don't think there is enough room for flywheel install.
    I'd say the flywheel is wrong yet he claims one from a '68 350 won't fit either so .... sumpin' ain't right here.
    Deuces and Desoto291Hemi like this.
  24. 31Apickup
    31Apickup
    As ss327 stated you need to rotate it around until it lines up. Here’s my small journal 327, the end of crank, where only one or so bolts line up then rotated around until all line up.
  25. squirrel
    It never occurred to me that someone would try to install the flywheel without aligning the dowel hole...I always do...but then I guess I'm weird.
    mctim64, 19Eddy30, alanp561 and 9 others like this.
  26. jimmy six
    jimmy six
    GMC 6’s are the same with no dowels. One way but I have a crank where the assembler got 5 in right and 1 with a big impact. I’m sure there are thousands of stories others here on the HAMB can tell.
    Wanderlust likes this.
  27. chasracer
    chasracer
    You have to align the dowel hole to get any of them lined up correctly. You don't have to have a dowel pin.
    Mr48chev, '34 Ratrod and Deuces like this.
  28. Roothawg
    Roothawg
    So what happened?
  29. 1971BB427
    1971BB427
    from Oregon
    Early two piece main seals didn't use the dowel. Which makes me wonder about the flywheel shown, as it's got the extra hole for a dowel that it shouldn't have? But maybe it's just the way they're made?
    Since the one piece main seals engines had an externally balanced flywheel, they needed a dowel pin to clock them correctly. The two piece main flywheel can go on any direction and work.
    Budget36 likes this.
  30. 26Troadster
    26Troadster
    from Texas
    i know i'm late to the party, but i don't believe i have ever seen a flywheel that looks like that one. all of mine the face covers the whole side then all you can see are the teeth on the starter ring.. i that one for something like a chevy II?
