A mate of mine has a 283 chev motor in his 50 Pontiac and is worried about the temperature going too high in the summer and in traffic, he asked me to try and find the normal/optimum temperature that it should run at - so I figured this would be the best place to try. Can anyone help?? thanks Bob
Personally, I want it to run between 180 and 210. 180 on the road with it climbing to 210 in heavy traffic. You want a minimum of 180. The upper limit will depend on the make up of your cooling system. If you are running a modern radiator with a 15# pressure cap and a coolant recovery system, it can opperate in the 220 range safely as all the new cars do. I've cooled a few 283s with original non-pressurised radiators and mechanical fans. That's why I like the 180-210 range. No boil over if kept below 212. It can be done with out electric fans and high dollar radiators. Good luck.
Well Put! FWIW - this is the exact answer I came up with when I asked the same question. It's based on a consensus of opinions from guys I trust.
