Hot Rods Chevy 250 / auto
Discussion in 'The Hokey Ass Message Board' started by 36roadster, Dec 10, 2016.
  1. What auto would be behind a 250 in a 1975 Chevy Nova? I am looking at an engine/trans swap into a 47 Chevy.
  2. squirrel
    Probably the light duty version of the TH350. They don't have quite as many clutch plates as the V8 version.
    If it's original, that is.
  3. mr.chevrolet
    mr.chevrolet
    would that be the Metric 200?
  4. steinauge
    steinauge
    from 1960
    I dont believe so .The 350 is a non overdrive trans.Another one that will work is the aluminum powerglide but you will likely like the 350 better.
  5. squirrel
    No, not the 200. The one I'm talking about is a TH350, it's just a slightly different version than was used behind the larger engines. They saved a buck by using clutch packs with fewer plates.
    porknbeaner likes this.
  6. many years ago i had a 1976 Chevy Nova with a 250 6 cylinder and th350. that transmission found it's way into a model A ford with a 283......worked just fine for many thousands of miles
  7. So it sounds like the bolt pattern on the 250 is the same as SBC? They are a rare engine here, so hard to get any info/measurements here.
    Thanks for the replies!
  8. squirrel
    yes, the back of a 250 looks and fits just like a 1955-85 V8.
  9. 40Standard
    40Standard
    from Indy
    turbo 350 tranny
  10. 56sedandelivery
    56sedandelivery
    There's a possibility it could also be a TH250; looks like a TH350, but has a band adjustment screw/nut just behind the cooler line ports of the transmission. Then again, it could also be a TH350C or a TH250C, with the lock up torque converter. I am Butch/56sedandelivery.
  11. squirrel
    I didn't realize they had the TH250 in 75...it could be.
    The lockups came along in 1979, so if it's one of them (with a 4 pin electrical connector near the shifter) it would have been swapped in.
  12. Paul B
    Paul B
    I have a 250 out of a 74 nova it has a 350
  13. squirrel
    73 was the last year for Powerglide...
  14. flamin01a
    flamin01a
    I have a 63 230 truck engine, and a 350 turbo trans from a v-8, can I put them together? flywheel, starter, etc?
  15. squirrel
    should work fine. Make sure the block is drilled for the starter before you get too far. Should be 2 or 3 bolt holes on the bottom of the block, on the pass side, at the back.
  16. belair
    belair
    In case you guys haven't noticed, FOR THE MOST PART, (squirrel will know the exceptions) if it bolted up to the back of a SBC, it will bolt up to a 194, 230, 250 and 292. Once again, the interchangeabilty of Chevy parts makes life easy for us of the orange blood.
  17. squirrel
    The only differences have to do with the flywheel, the crank flange changed on small blocks in 86, and the 292 had two different designs, one normal, one with 3 dowels and 1/2" bolts. Also the 400 and 454 had weighted flywheels.
    And those early engine blocks that weren't drilled for starters.
    belair likes this.
  18. belair
    belair
    I told you...
    squirrel likes this.
  19. jimmy six
    jimmy six
    In 1970 I bought my mom a Nova with 250" 6 and automatic. It was a 200. It had 3 speeds and served her very well for 150k miles. I sold it to a friend whose daughter was going to college. It went on to run well over 200k miles with no major work of any kind. The trans recieved only oil and filter changes at 50k intervals.
  20. jimmy six
    jimmy six
    Correction the trans was a 250...
  21. squirrel
    huh, I thought they didn't make the TH250 trans until a few years later. Interesting.
  22. jimmy six
    jimmy six
    Jim your right on that 250's did not arrive until 74. Must have been a 350.. No wonder it lasted so long with no problems.
