Well after sitting for a couple weeks with acetone and trans fluid down the fire hole and rocking it it final broke free! Can turn it over by hand now. There was no oil in the pan when I went to train it.Took the valve cover off made sure all valves aren’t stuck. Going to put oil in it and see if I can get starter to turn it over.If that all works ,put new plugs check points, see if I can free the carb throttle it is stuck. Then try and fire it. Am I missing anything? Sent from my iPhone using H.A.M.B.
