Just was looking around and reading alot up on the trans adapters . Ive got the idea of how this works and i want to build my own . I found a small block chevy bolt pattern (blue print) online .It gives me everything i need for that part of the plate . Is there one of these prints floating around online for the 216/235 blocks ? I got really close with veniers before i found the print of the small block . Im sure i could get really close with the 216/235 but it would be great to have the print . Anyone got the print or #s and would be willing to share ? Crank shaft centerline to bellhousing bolt hole locations is what im after. Im going with a 200R4 behind my 216 until i get the 235 done. Already have trans and s10 4x4 rearend (drums) 60", just need drive shaft and adapter fabbed and a few misc things to wrap it up . Thanks
I don't know if Keith Hardy's site http://chevy.oldcarmanualproject.com/index.htm which has 1000's of pages on Chevy documents might have what you need or not. Might be worth looking. Good luck.
