CHEVROLET CLUTCH DISCS AND PRESSURE PLATES Location: D/FW - Hurst, TX Price: Varies - See Ad All Chevrolet: 10 spline clutches are for 37-54 Chevrolet ½ Ton Trucks: 2 - 10" 10 spline Clutches - low miles (100 or less) - $15.00 ea. 14 spline clutches are for T-5 Transmissions found in S-10 trucks and SUV’s and in Astro Vans. They will work with the flywheels listed below and can be used to install the T-5 transmission in the 37-54 Chevrolet ½ Ton Trucks: 2 - 10" 14 spline Clutches - very low miles (50 or less) - $15.00 ea. The Pressure plates are for the either the 6 volt flywheel or the 12 volt flywheel. 2 - 10" Pressure Plates - $40.00 ea. 1 - 10" Clutch Kit - 10" Pressure Plate, Throw Out Bearing, Alignment Tool, Pilot Bushing, pick your 10" Clutch Disc from above (this kit is virtually new with less then 25 miles miles on it and is the kit needed to install a T-5 transmission in your 37-54 ½ Ton Truck) - $75.00 I accept PayPal. Questions: [email protected]
