SOLD SOLD I am posting this for my brother Dave who lives in Sedalia, Missouri. He built this 327 large journal engine and it is for sale. The 1968 block is a factory large journal with casting number 3914660. It is a 2-bolt main block. A local machine shop hot tanked it and installed new cam bearings and new freeze plugs. It was not decked and was/is within tolerance to use at standard bore. The original cast crank was reground .010r ,010m. The machine shop also recon’d the stock connecting rods. Pistons are new cast flat-tops with Hastings rings, Engine Pro rod and main bearings were used. Camshaft is an RV hydraulic by Melling #MTC-1. Lifters, timing chain and oil pump are all new from Mellings. All gaskets are Fel-Pro. The heads are 305 HO heads with all new valves and new Z-28 valve springs. Seats were done by the same local machine shop. Intake manifold is a new Edelbrock Performer with a new Edelbrock 600 carb with electric choke. Distributor is a new aftermarket HEI with new cap, rotor, and wires. Exhaust manifolds are stock ram horns. New water pump, fuel pump, starter, alternator, and flex plate. Valve covers and air cleaner are new aftermarket polished aluminum. Everything on this engine is either new or rebuilt and painted. The engine stand was built so he could start it before installation and make all adjustments on the stand and check for any issues like oil leaks. The stand is very nice with battery, gas tank, and dash panel. The entire stand has been professionally welded, powder coated and installed with nice casters. It has an oil pressure gauge in the dash panel as well as a keyed ignition switch. The engine has been oil pressure primed, valves adjusted and base timing set. Oil in the engine has had zinc added for break-in without camshaft damage. Potential buyer can hear the engine run! No guess-work! Price of the engine as seen in the pictures is $2700. The stand, complete with battery and gas tank as pictured, is $500 additional. Engine can be purchased with or without stand. Engine is located in Sedalia, Missouri. Seller can be reached at 660-287-0544 for any questions or to purchase. Seller can help with loading but transportation is buyers responsibility.
