Hot Rods Cheap but effective , body rotisserie.
Discussion in 'The Hokey Ass Message Board' started by Art Gertz, Mar 1, 2025.
  1. Art Gertz
    Art Gertz
    Not my design but found on Market Place. Uses 3/4" real plywood and 2x4"s. Mounts on unit body or frame horns, front/back. Plywood cut into quarter circles, mounted on edge to 2x4 frame pieces. Floor or bottom of frame will roll/tilt to vertical, or other designed-in angles. Leave 2x4 long enough for leverage, with notch for jack stand support. Mounting height to body CG. will determine effort required or wanting to roll past 90 deg. YOUR results will vary.
    Cheers, Art.
  2. choptop40
    choptop40
  3. lostone
    lostone
    from kansas
  4. 49ratfink
    49ratfink
    I built one from scrap metal for free
  5. Budget36
    Budget36
    Real plywood as opposed to fake plywood?
  6. alanp561
    alanp561
    Found this, for $200 bucks, didn't look too bad.
    The 39 guy likes this.
  7. ekimneirbo
    ekimneirbo
    While a rotisserie looks like a simple machine, it would take a fair amount of work to create one ......and to get it to work correctly. Best bet is to buy a used one...........use it.........then resell it for what you gave for it. (IMHO):) They don't depreciate if you get a used one.
  8. To each his own, but for me if I am going to go through all the trouble to disassemble a car & put it on a spit....It is a car that I value a bunch. I would not trust something made of wood & unless I built it myself, I would not trust a homemade steel one either.
    There are somethings you can skimp on, but this is not one of them!
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
    ekimneirbo and SS327 like this.
  9. nochop
    nochop
    from norcal
    I saw one somewhere built out of huge wood spools for cable or wire
  10. ekimneirbo
    ekimneirbo
    Well said................The bodies can be relatively heavy but are also somewhat awkward as they are rotated and can get away from someone if they aren't careful or have it mis-balanced. Once its adjusted properly it rotates easily, but that first guess as to the balance point can be a problem. :)
    Bill's Auto Works likes this.
  11. Happydaze
    Happydaze
    I built mine based on the Red Wing plans, available free to download. Beefy enough for a full size car. Working on the underside at a comfortable working height is incredible.
    Chris
    ekimneirbo and guthriesmith like this.
  12. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Now that is useful information! Thanks for sharing. I may just have to build one like that.
    Happydaze likes this.
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    ekimneirbo, Packrat, RMR&C and 2 others like this.
  14. finn
    finn
    After wanting one for years, and procrastinating about making one, I finally bought a ready made one. I realized that inertia and time wasn’t going to let me cobble something together.
    Now my kids can argue over who has to figure out what to do with it once I’m gone.
