Technical Cheap bought online epoxy primers
Discussion in 'The Hokey Ass Message Board' started by VonMoldy, Jun 7, 2019.
  1. VonMoldy
    VonMoldy
    from UTARRGH!
    If I were spraying an entire car I would just buy it by the gallon at my local paint shop. i just need a quart or less and had a heck of a time trying to find a normal epoxy primer at 3 or 4 shops I asked about it.
    Has anyone used UPOL Raptor, eastwood, speedkote or summit?
  2. 19Fordy
    19Fordy
  3. VonMoldy
    VonMoldy
    from UTARRGH!
  4. UPOL Raptor is a bed liner not an epoxy.
    gimpyshotrods likes this.
  5. VonMoldy
    VonMoldy
    from UTARRGH!
    "UPOL Raptor is a bed liner not an epoxy."
    uh ok.
    anthony myrick likes this.
  6. I use Summit and Kirker which I believe to be the same product. Zero complaints.
    VonMoldy likes this.
  7. 19Fordy
    19Fordy
  8. vtx1800
    vtx1800
    I am surprised you can’t purchase epoxy primer in quarts. The shop I buy my supply’s from sells it that way.
  9. LM14
    LM14
    from Iowa
    I used Eastwoods on one project. Wasn't that impressed with it. It was always sticky/gummy and a bitch to sand. Even called them and went over the process and I was doing everything right. Several months later it was "normal" and more what I expected. Talked to a few others on a message board that were having the exact same results as I was. Wouldn't buy it again.
    SPark
  10. dalesnyder
    dalesnyder
    I use kirker brand, it has no induction time. One less thing an amateur like me can screw up.
    Just Gary likes this.
  11. southcross2631
    southcross2631
    I use kirker epoxy primer from U.S. Body source catalog . Have painted over 10 cars with no issues.
    Frankie47 likes this.
  12. slowmotion
    slowmotion
    The NAPA I deliver for carries epoxy primer in quarts. I just did a new welding truck bed for my son in black epoxy. Used TranStar. Use a good respirator.
  13. low down A
    low down A
    i did a 56 chrysler a couple years ago with eastwoods flat black two part epoxy no matter how many coats you could see the body filler underneath. alway's have used ppg's epoxy but it's getting expensive next car i'll use ppg . no such thing as cheap and good when it applies to paint. oh yea i would consider eastwoods paint JUNK
  14. PPG shopline has quarts
    Also PPG has an industrial epoxy that works great. It’s the old DP, mixes 1:1 like it used too
    Runs me about $125 for a 2 gallon kit
    Look up TAMCO
    I like everything I have used from them
    texasred likes this.
  15. Ericnova72
    Ericnova72
    from Michigan
    Frankie47 and jaw22w like this.
