Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. Seat came out nice; your buddy did a good job.
  2. Tim
    Tim
    from KCMO
    Shit that seat looks perfect! Who cares how it got broke in lmao
    Stogy and loudbang like this.
  3. Runnin shine
    Runnin shine
    It’s hard to believe and seems more than coincidence that I retired from the “biz” just a short while ago and quit making the monthly payments on the storage shed that held a lot of old worn out set props. Somehow “Trusty Rusty the dirty love couch” winds up under your tired butt. The truck is a class act but your just nasty.
    bchctybob, Stogy, tb33anda3rd and 2 others like this.
  4. dumprat
    dumprat
    from b.c.
    Hahaha!
    Jeremy said it makes him smell nachos and ass every time he sees it.!!
    It is the cheap ass 34 after all..... did ya all think I was kidding?
    bchctybob, Stogy, loudbang and 2 others like this.
  5. Tim
    Tim
    from KCMO
    Bahahaha I think about that every time someone’s used a curbed couch for material.
    Stogy, loudbang and Six Ball like this.
  6. dumprat
    dumprat
    from b.c.
    Cracked both front spring bushings in the spring. Not sure how I managed that. Maybe too much weight. I'm going to replace them with oil impregnated bronze ones.
    It wanders a bit with loose bushings and no panhard.
  7. Tim
    Tim
    from KCMO
    Dang that’s a new one
    RICH B, loudbang and Stogy like this.
  8. dumprat
    dumprat
    from b.c.
    And somehow I lost the oil cap, I assume it vibrated off....
  9. Stogy
    Stogy
    That could be real messy...the Shakedown continues...remember that weird sound you heard the other day...
  10. Six Ball
    Six Ball
    from Nevada
    I never heard of the bushings cracking before. That's why they are made of soft stuff just supposed to moosh a little. :rolleyes:
    bchctybob and loudbang like this.
  11. Tim
    Tim
    from KCMO
    Little hole and some safety wire and when the oil cap comes off you won’t have to buy another one?
    loudbang, Six Ball and Stogy like this.
  12. dumprat
    dumprat
    from b.c.
    These are your typical street rod plastic ones. Not sure why they cracked. Both did it right on top. I could see if they did it where the gap in the leaf spring was. Bronze will fix it.
  13. Tim
    Tim
    from KCMO
    You over there doing some Duke brothers shit with that thing? Lol
    Woogeroo, loudbang, Stogy and 3 others like this.
  14. Six Ball
    Six Ball
    from Nevada
    Oh. plastic hot rod stuff AMT, Monogram, or Revell? Put a long wire on the cap so you can hear it dragging on the road when it comes off. :D
    Outback, loudbang and Stogy like this.
  15. Stogy
    Stogy
    Just married!!
  16. dumprat
    dumprat
    from b.c.
    No but with the whopping 3/4" of front suspension travel it has come down hard a couple of times.
    Outback, bchctybob, loudbang and 2 others like this.
  17. Tim
    Tim
    from KCMO
    Mmm yeah that’d do it. Been there
  18. Six Ball
    Six Ball
    from Nevada
    I'm trying to get at least a couple of inches on the roadster but that may just give it more of a head start?
  19. Tim
    Tim
    from KCMO
    After my 46’ front spring settled I had an inch before it bottomed on the upper shock mounts
    Hard enough to rip them off the frame. Definitely gonna be notching the frame on the A which has way less room to play with before it hits
    bchctybob, Six Ball and loudbang like this.
  20. dumprat
    dumprat
    from b.c.
    My axle bottoms on the front spring plate. I put a streetrod plasma cut one on instead of a cast one. It gained my almost 3/8"
  21. Stogy
    Stogy
    So you have to add a leaf or two...or is the spring too wide or short?... the shackles from what I understand sit at around 45 degrees or so under load with all my very little knowledge of such things...any Death Wobble...?
    brady1929, Six Ball and loudbang like this.
  22. dumprat
    dumprat
    from b.c.
    No wobble of any sort. It drives awesome!
    Shackles are at a perfect angle. I might need to replace the whole spring. It's probably just sagged out too much. I am reluctant to do that because it sits nicely.
  23. Tim
    Tim
    from KCMO
    So all that being said you should probably go do some duke brothers stuff with that truck and send me the video to share haha
  24. dumprat
    dumprat
    from b.c.
    Two broken bushing hats. Not sure why. I replaced them with bronze . I will likely replace the shackles themselves this winter. Not a big fan of plastic. IMG_0516.jpg
  25. Tim
    Tim
    from KCMO
    That’s where mine failed as well. I was picturing it in the barrel part.
    It wasn’t uniform just the rear facing ones and not all of them.
    I do drive the car hard and hit massive pot holes occasionally as well so I’ll just list them as a wear item and move on
  26. dumprat
    dumprat
    from b.c.
    I'm not stoked as they have limited miles on them.
    Outback, loudbang and Six Ball like this.
  27. Tim
    Tim
    from KCMO
    Yeah you’ve driven around the block like ten times they shouldn't be busted I’d replace them like you did too
  28. Six Ball
    Six Ball
    from Nevada
    Don't we all?
  29. The37Kid
    The37Kid
    Nice T body on a 26-27 frame, what are the plans?
    Bob
