Projects Cheap ass 34 pick up
Discussion in 'Traditional Hot Rods' started by dumprat, May 31, 2015.
  1. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    It sounds like this 2 speed QC build needs a thread of its own (PLEASE PLEASE PLEASE)!
  2. Cutlas Fan
    Cutlas Fan
    A great project. Hopefully most of your problems are behind you although it makes for an interesting and informative read seeing how you solve those problems! Deciding to use the hemi will put the "hot" back into "hotrod" although I hope you find a use for that flatty.
    kidcampbell71 and loudbang like this.
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    As patmanta said, That 2 speed Halibrand deserves it's own thread.
    I know that some were made but have no details. Someone told me they had one some years ago, but I'm not sure who it was. Maybe CRS will kick out for a few minutes and I can write it down.
    Stogy, brEad, loudbang and 2 others like this.
  4. Hmmm, you have no room for your rt foot on the accelerator either. My knee just doesn't dislocate like that.
    Stogy and loudbang like this.
  5. dumprat
    dumprat
    from b.c.
    I think I can make the spoon throttle fit. It won't be the same as stock but should work. I won't be able to drive with boots on though.
    Stogy, Runnin shine and loudbang like this.
  6. I built a ‘32 Ford pickup from scratch, and can say without hesitation that fitting three pedals and making them functional was by far the most challenging task of the whole project.
  7. dumprat
    dumprat
    from b.c.
    IMG_1745.JPG Just finishing up the welding and fab work on the frame, but the wife interrupted my to help tile the kitchen back splash. So after cutting tile for a couple hours I figured a change was in order so I fooled with my oil pan mods. I used a 318 truck pan sump to make my Desoto pan more marine like. It will get a trap door, windage tray and a few other silly bits. Just for fun.
    ratrodrodder, Stogy, bct and 10 others like this.
  8. Mikko_
    Mikko_
    from Sweden
    Don't know how I missed this thread but I'll subscribe from now on.
  9. FL_Dave
    FL_Dave
    Do you still have the cam by chance?
  10. sloppy jalopies
    sloppy jalopies
    I see things man !
    doesn't that upside down oil-pan with the bottom cut out look like a tiny '50s pedal car at the body shop...
    Stogy, brEad and loudbang like this.
  11. dumprat
    dumprat
    from b.c.
    IMG_1796.JPG All the welding is finally done on the frame and it's off to the sand blaster this week, which means I get to start on the engine!
    I have eaten all the zip disc dust I can stand for a while.
  12. That’s a huge step Dumprat! Well done!
    greaser, loudbang and Stogy like this.
  13. dumprat
    dumprat
    from b.c.
    Thanks Ryan. It's been a lot of dirty work and I am looking forward to finishing parts and bolting them on for a change.
    loudbang and greaser like this.
  14. Runnin shine
    Runnin shine
    Too bad it’s a weekday. March 16ths should be spent in the garage. Maybe opening packages of needed parts?
    Stogy likes this.
  15. dumprat
    dumprat
    from b.c.
    Ya instead. Am stuck at work listening to covid hysterical BS and suffering with computers that don't work....super fun!
  16. dumprat
    dumprat
    from b.c.
    IMG_1806.JPG Let the games begin!
  17. Aaron D.
    Aaron D.
    Cool man, please post pics of your engine build.
  18. Six Ball
    Six Ball
    from Nevada
    Seeing clean engine parts going together is exciting!
  19. dumprat
    dumprat
    from b.c.
    Sure if people want. I am going to do a bunch of goofy stuff that I have been thinking about.
  20. Mike Colemire
    Mike Colemire
    We like goofy stuff too!
    brEad likes this.
  21. dumprat
    dumprat
    from b.c.
    IMG_1807.JPG My buddy got my frame blasted! So I spent a couple hours getting the first fill on the rust pits now that they are cleaned. Maybe I can get it in primer by the end of the weekend if I keep on it!
    brEad, Stogy, Bondo Slinger and 7 others like this.
  22. Runnin shine
    Runnin shine
    I know you loved the 6 and it was going to be fairly unique. You also proclaimed it would be a strong runner. But it seems if only visually the truck is going to be a different beast all together. Has your mind been anxious about the prospects of a more aggressive acceleration? Or worrisome over parts abuse and tire annihilation?
    kidcampbell71 likes this.
  23. dumprat
    dumprat
    from b.c.
    I don't worry about much!
    I am on the hunt for a limited slip for the rear and maybe a set of aftermarket axleshafts. Given that the engine has somewhat changed the flavour of m truck it opens up a few more options. I still plan on running my 7.00-16's on the rear with steel wheels but I also picked up a really nice set of aluminum slots that I am thinking of mounting some 31" pro trac or MT sportsmans on. Just because.
  24. Runnin shine
    Runnin shine
    The vision for my truck keeps evolving as well. I no longer seem interested in my initial wheel/tire combo. My minds eye only seems to see the strip set up now. It is however nice to think how a swap back or forth completely will switch up the trucks image, well at least to me. You have planned the same deal I do believe.
  25. Six Ball
    Six Ball
    from Nevada
    Aside from the need of getting power to the ground a change of wheels and tires is the cheapest and easiest way to change the looks of a car. It is also the most temporary change and can be totally reversed. A total change in attitude is possible and still be right for the build. Just sayin' :) The frame looks great! A little sunshine and I'll be blasting mine. Going to try a blast attachment for my pressure washer.
  26. dumprat
    dumprat
    from b.c.
    Primed and ready to scuff and paint next weekend maybe if the weather holds. IMG_1809.JPG
    kidcampbell71, Jeff34, brEad and 12 others like this.
  27. Six Ball
    Six Ball
    from Nevada
    That look nice. Hope to blast mine this week.
  28. dumprat
    dumprat
    from b.c.
    Note:
    ARP bolt torque lube is like stripper glitter after a business trip, is everywhere and somehow ends up all over the place, under your elbows and in your ear. It seems as impossible to wash off as well!
  29. Six Ball
    Six Ball
    from Nevada
    You say that like it's a bad thing. :)
