CHEAP and Great Alternative Coil Springs '49 thru '59 Ford and Merc
Discussion in 'The Hokey Ass Message Board' started by Fairlane Dave, Apr 26, 2008.
  1. Lono
    Lono
    Anyone put them in a 49-51 plymouth?
  2. junkyardjeff
    junkyardjeff
    Anyone still running a Y block with the aerostar springs?,my 55 will be going back to a Y block and will need to replace the shortened springs I have in it now since they were designed for a 351-W and C-4.
  3. Lono
    Lono
    Oh, forgot to add another..
    I've got them in my 50 Ford as well.
    Perfect ride, perfect stance... perfect suggestion in the first place. You've saved me a lot of money over the last few years and made driving a whole lot more enjoyable.
    Thank you for posting this back in 2008 Fairlane Dave!
  4. meteor
    meteor
    Has anybody tried the aerostar springs on a 57 ford with dropped spindles?
  5. ynottayblock
    ynottayblock
    looks like that will be what I will have to do. I was hoping somebody had tried it already
  6. hoop98
    hoop98
    from Texas
    I grabbed 3 S10 4 Cylinder Springs and the Aerostar and built a chart to compare any Moog Spring to others.
    I put in a Wheel Load of 900 pounds and aa motion ratio of .53 (Gen 2 Camaro)for direct comparing springs.
    The compare height is the difference at the fenderwell (spring ht / motion ratio.
    Hoop
  7. hoop98
    hoop98
    from Texas
    BTW, I've searched all Moogs and that's only spring that size and rate in the ballpark, good job.
  8. hoop98
    hoop98
    from Texas
    Here is my spreadsheet loaded with all Moog Springs;
    You can view it here
    Under the file option you can download a copy.
  9. Doctor Detroit
    Doctor Detroit
    Hoop98, interesting info you've provided, thank you. I have the Moog CC850 is my '51 Merc now, along with dropped uprights. I'd like to find a coil spring that is approximately stock height, to raise my front end just a little bit. It appears that a Moog 5662 is a similar spring, but about 2 inches longer installed height. Am I reading this correctly?
  10. hoop98
    hoop98
    from Texas
    The 5662 would sit about 3.6 higher.
    I would try the 5658 and cut off 1/2 a coil, that would stiffen that up close to the CC850 and be in the 2 inch higher range.
    Remember because you have almost a 2-1 leverage from spring location an inch taller spring at the same load would raise the car near 2 inches.
    Hoop
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    Instead of chopping the coil and changing it's tension you can get different thicknesses of spring seat pads from Energy Suspension.
  12. hoop98
    hoop98
    from Texas
    A 1 inch thicker seat pad would raise the car 1.8 inches, same rate.
    The 5660 is roughly the same spring rate as the CC850 the 5568 is 75 pounds/in softer.
    Since we have a Tangential End we can safely cut the spring on that end.
    I have "cut" the springs for you here using Hookes Law.
    Remember we are cutting the "Height" not the length.
    So as pictured above, we are raising the car by either 1.5 (5658) or 2.2 (5660)
    If you want to know your motion ratio here is an easy way.
    Put a tie wrap around the shock rod.
    Bounce the car a couple of times then measure the fenderwell height.
    Push the tie wrap down to the bottom of the shock rod.
    Get 2 people to sit on the fender (gently)and remeasure.
    Measure how much the tie wrap moved.
    Divide that by how much the fender moved and that's your motion ratio.
    The one I used above is from a Camaro and should be close enough for government work.
    Hoop
  13. flynstone
    flynstone
    any one know if they will work on a 64 gal ?
  14. flynstone
    flynstone
  15. Tate
    Tate
    64 Galaxie? probably too low, see here http://www.jalopyjournal.com/forum/showthread.php?t=692390&highlight=lowering+galaxie
    Combining the knowledge in that thread with this one, it looks as if the taller S-10 springs might work on a Galaxie. I searched on the HAMB and couldn't find anyone who has tried it, if I had a Galaxie I would give it a shot. I get to drive my mom's 64 Galaxie when I visit home, but I don't think the old man will let me lower it for her ;)
  16. flynstone
    flynstone
  17. Cabbage
    Cabbage
    1. S.F.C.C.
    Finally got Bad Betty on the road, i really like the Aero springs.The ride is nice and she sits just right :)
  18. daddio211
    daddio211
    Pics?
    Sent from my DROID device using the TJJ mobile app
  19. Cabbage
    Cabbage
    1. S.F.C.C.
    sorry the HAMB doesnt like my pics, says the are not a valid image. yes i resized them way down. any ideas?
  20. Cabbage
    Cabbage
    1. S.F.C.C.
  21. daddio211
    daddio211
    Bitchin!
  22. Edsel101
    Edsel101
    Here is a picture of my 59 Edsel that I just finished up with the aerostar springs. I originally had bought 2 inch drop spings. I installed them and wasn't satisfied with the look. So I pulled them and installed the aerostars! I wish I would've found out about this before I bought the 2 inch drop springs! [​IMG]
  23. 61unib100
    61unib100
    from Alpine, Ca
    Looks good. What did you do out back?
  24. Edsel101
    Edsel101
    Thanks! I used a two inch block.
  25. 61unib100
    61unib100
    from Alpine, Ca
    I just picked up my coils and 2" blocks for my 58 edsel Pacer. Can't wait to install and see how it looks.
  26. iFlip
    iFlip
    from San Angelo
    Picked some up for my 57. Having a hell of a time getting the old springs out though. Should just have to drop the lower control arm correct? Anyone have like a picture guide of how to do it? Would really appreciate it.
  27. 61unib100
    61unib100
    from Alpine, Ca
    Ya I would imagine that's all you have to do. Is the spring stuck to the control arm? Or is the arm just not dropping enough to get it out?
  28. fordsbyjay
    fordsbyjay
    from Lafayette
    Sometimes you have to just pry the spring out as the last coil will be hung up on the lower control arm.
  29. iFlip
    iFlip
    from San Angelo
    Just can't get the lower ball joint out to drop the arm.
  30. Dakota
    Dakota
    from Beulah, ND
    Who here has done them with the Granada Spindles and the aerostar springs?
    I have the spindles, but havent installed them, but i have heard that they drop the car as much at 1.5 inches just with the spindles, so im worried that the car will be too low with both.
    This is in the 57-59 Ford, i will be using them in a 58 Edsel wagon though.
