Hot Rods Chain driven blower on a flathead?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Mar 30, 2018.
  1. kustomdeluxe
    kustomdeluxe
    Do you or can you find more info about this picture. Was it on a persons page? I need info on that intake manifold. I’ve got a 3-71 blower going on a 8BA and have been searching for an intake suitable.
    Thanks!!
  2. Fordors
    Fordors
    That looks like a 4 bbl. manifold that was milled flat and most likely the plenum was opened up, then a 1/2" thick plate was bolted on to support the blower. Your 3-71 has only one outlet and it would work well with a modified 4 bbl. manifold, and if you consider going this route put the blower on top of the engine centered where it would be mounted and see if an off the shelf snout might be out there that would work. When you are measuring the length of the blower snout, keep in mind you will probably need to drive the water pumps with a separate belt.
    What are you considering for a drive system, Gilmer belt or v-belts? Take a look at this website for some ideas-
    http://uncommonengineering.com/
  3. Anyone ever hear of a Ford 427 cammer, what made the cams go around? Many other engine timing chains are double row chain, the trick is proper tension and lube.
    The advantage of a belt is the tiny bit of "give" in the rubber teeth that absorbs the power pulses.
  4. Deuces
    Deuces
    There's always a gear drive setup for the Ford SOHC 427 motor.....
    What a freakin' nightmare!!!!:confused::rolleyes:
  5. nunattax
    nunattax
    from IRELAND
    my thoughts exactly
  6. nunattax
    nunattax
    from IRELAND
  7. Deuces
    Deuces
    That too!!!..... :eek::rolleyes:
    Kinda like a Pete Jackson gear drive only worse....
  8. khead47
    khead47
    Wasn't there an aero engine powered land speed car that had a chain drive that decapitated the driver when it threw the chain ? About a hunnert years ago.
  9. kustomdeluxe
    kustomdeluxe
  10. Gasoline Junkie
    Gasoline Junkie
    I know chains were phased out early on, but can't help but wonder why. If you think about it, timing chains are better than belts right? I know belt slip on a blower is a major issue and I feel like a chain would be ideal. If you enclosed it and it was oiled and had a tensioner on it.
  11. Gotgas
    Gotgas
    from DFW USA
    Because engines have high rpm misfires and backfires that radically affect engine speed. A roots blower has a lot of inertia of its own, so many times the link between the blower and the engine it's on serves as a 'fuse' of sorts. A rubber belt will deal with minor hiccups better, or when things go really wrong and the belt gets thrown, a belt has much less inertia than a chain does - resulting in less damage to the engine and anything surrounding it.
