Technical ceramic coating Aluminized tubing ?
Discussion in 'The Hokey Ass Message Board' started by divco13, Feb 27, 2018.
  1. Can you ceramic coat Aluminized tubing. Such as Automotive Exhaust Headers
    Going to Fab a new set of 2' headers for the Divco. IMG-20120818-00509.jpg .
  2. i've had it done after it's been sandblasted
  3. Blue One
    Blue One
    from Alberta
    Most exhaust headers are not fabricated from aluminized tubing, but rather from bare mild steel, and in some cases stainless steel.
    That's because aluminized tubing can create problems with welding.
    In any case they do sandblast before ceramic coating.
    I build Headers, here is a set, 304 stainless, using 308 rod
    Just thought I would ask if anyone here has Ceramic coated Alum tubing. Clean the tubing, Tig welds just fine.
    Of course it has at least needs the shot penned, in order to be clean for oils
  5. Can you ceramic coat Aluminized Tubing?
    Yes, We have coated aluminized tubing - for that matter we have coated Aluminum manifolds, cast Iron, Stainless, mild steel, and even certain plastics!
