Event Coverage Central city Iowa swap
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Oct 1, 2021.
  1. ahshoe
    ahshoe
    Empty qt oil cans were in the $20 each range. I bought 4
    Stogy likes this.
  2. Stogy
    Stogy
    Thanks for sharing the event @Moriarity...I miss those in many ways...
    Thanks to the others sharing the event as well...
    VANDENPLAS and Moriarity like this.
  3. swifty
    swifty
    Thanks for the pics @Moriarity. On your 4 barrel Holley what is the barb/hose fitting which comes out adjacent to the front fuel bowl? Not really familiar with 4 barrels and trying to use one to test run my Nailhead.
  4. continentaljohn
    continentaljohn
    Thank you for taking the time and sharing the pictures looks like a nice swap
  5. Corn Fed
    Corn Fed
    It was good to finally meet @Moriarity and see some familiar faces.
    Yes it was smaller, but I think there was a less percentage of the brickabrack crap. In football you could call this a rebuilding year. With it being a totally new location, I'm sure the club will have learned a lot on what worked and want didnt.
    Assuming it continues, I will keep going.
    Moriarity likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    Are you talking about the chrome line that comes from both float bowls? That is simply a dual feed holley fuel line
  7. swifty
    swifty
    No @Moriarity, it's the fitting to the left of the RHS fuelbowl/carb body joint. I think it takes a 1/4" rubber hose.
  8. 24riverview
    24riverview
    This one? Ported vacuum source if that's your preference for vacuum advance, etc. Some Holleys have a 1/8 pipe threaded hole there.
    swifty and Moriarity like this.
  9. swifty
    swifty
    That's the one!! Thanks for that @24riverview My carb has the 1/8' NPT tapped hole with a hose fitting screwed in there. No other fittings on the manifold so wondered where the vacuum for the distributor was coming from.
  10. spinzzy
    spinzzy
    from indy
    Hello I’m in Lebanon Indiana I see where you posted a tether car it had pacemaker front wheels wonder if you would be interested in sell it did have an engine in it here’s my number you can call me 317-340-5953 thank you
  11. cs39ford
    cs39ford
    I have no tether car at this time. Photos were not taken or posted by me. Sorry
  12. ahshoe
    ahshoe
    Is the Spring one that used to be at Hawkeye downs going to happen this year and if so Where?
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    looks like it is
    Bugguts likes this.
