Caution: early Ford bolt on dropped spindle arms
Discussion in 'The Hokey Ass Message Board' started by hotrod-40, Jun 3, 2012.
  1. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yeah, that would work too.
    Don
  2. mustangsix
    mustangsix
    Lots of recommendations for loctite, but be cautious when using any kind of sealer on a blind hole. Too much and you can cause a hydraulic lock that can damage the part or give you a bad torque reading.
  3. I just give it a stripe up the threads of the bolt, I have seen some guys squirt it into bolt holes though...
    In torque formulas you can factor in things like loctite, lubricants, coatings, etc.
    Bob
  4. 296 V8
    296 V8
    from Nor~Cal
    Put studs in them / use all the treads
  5. bobscogin
    bobscogin
    There's no way a casting could be bent like I bent those Speedway arms. There's not a doubt in my mind that they are forgings as is claimed. Do you have evidence that refutes their claim, or are you just parroting the old "if they're Chinese they're crap" assertion? Just curious how much first hand experience you have with them.
    Bob
  6. 19Fordy
    19Fordy
    I think that using studs is a good idea , but it looks like the steering arms would not be easy to remove from the backing plate as the studs would cause "interference" issues with the axle when trying to remove the steering arms as it appears that the dropped axle almost touches the steering arm.
    V8-m likes this.
  7. I am told these meet and exceed Chinese DOT standards:D
    lothiandon1940 likes this.
  8. Bob metke
    Bob metke
    Has anyone dropped the stock steering arms?Any tricks?Thanks
  9. cammer8
    cammer8
  10. cammer8
    cammer8
