Technical cast steel crank vs. 4340 moly, Eagle
Discussion in 'The Hokey Ass Message Board' started by Budget36, Oct 17, 2019.
  1. Budget36
    Budget36
    I want to make a small block chevy a 383 for a tow rig, any reason the cast steel Eagle crank won't hold up, or should I step up to the 4340 Moly crank? 320 vs 620 dollars wise. Not looking to cheap out, but don't need a Marine engine, i/e doesn't need to be the best it can be.
    Might see 2-3K miles a year, max RPM's when the TH400 shifts pulling up a hill...maybe 5K-5.5K
    Anyone have insight?
  2. dirty old man
    dirty old man
    This is a point of disagreement amongst lots of engine building people. But myself I feel that if you're building a race oriented engine that you're,shifting @ 7K, ect,. yeah, you most likely will get better service outta the 4340 forged crank.
    But for the duty you describe, I think the cast crank should do just fine.
  3. oldiron 440
    oldiron 440
    Think 300 would cover the tow bill?
    Montana1 likes this.
  4. Mike VV
    Mike VV
    from SoCal
    NO one makes OR sells a "Moly" crank shaft..!
    Do you mean "Chromoly" ? Just calling it 4340 is a plenty good description.
    Again...details matter.
    Mike
    19Eddy30 likes this.
  5. Ask the opinion of your reputable, trusted engine machinist. He can tell you how many broken cranks have come back. Probably not many.
    450 lb/ft is possible, right? Spend the extra money on roller rocker arms and enjoy the horsepower.
    31hotrodguy likes this.
  6. partsdawg
    partsdawg
    from Minnesota
    How many 1990 and older trucks out there with the factory 350 have you heard of breaking cranks?
  7. badvolvo
    badvolvo
    I have run the scat cast steel crankshafts in a lot of small blocks, up to 600 hp without issues. Honestly, I built a 406 over 20 years ago with the stock cast crankshaft, the car run's in the 10's and has not been apart since it was built.
  8. treb11
    treb11
    For $620 you will NOT be getting a race grade forged crank. The standard crank will be fine. Use the $ on a balanced rotating assembly.
    Sent from my SM-G965U using The H.A.M.B. mobile app
  9. Budget36
    Budget36
    Here's the Description:
    Crankshaft, 1-Piece Seal, Internal Balance, Forged 4340 Steel, 3.750 in. Stroke, Chevy, 5.7L, Each
    https://www.summitracing.com/parts/esp-435337505700?rrec=true
  10. southcross2631
    southcross2631
    I think it's overkill for a tow rig. I ran a big block Chevy with a stock cast crank and turned it 7 grand for 3 years before it jerked a rod journal out after I started spraying 200hp of nitrous every pass.
    I had a documented 500 passes on that crankshaft. It was a used crank that I had turned and checked for cracks.
    A cast steel Eagle or Scat would do fine in your truck. My friend ran a cast steel 383 kit in his motor home for years pulling a 24 foot enclosed. Eagle crank, Eagle I beam rod's, Hyper piston's. The kit back then was less than a thousand dollars with a flexplate and balancer.
    31hotrodguy and dirty old man like this.
  11. We almost built a stroker for our tow rig
    went with a 500 caddy
    the cast crank should be fine, as long as ya don't put a blower on it
    seen some front hubs break
    scotty t and 31hotrodguy like this.
  12. Budget36
    Budget36
    Thanks all. Again, building for low end torque, won't be blown, revved high, etc.
    chevy57dude likes this.
  13. *Every* chevy stock 400 crank was cast. How many of those with cut down (from 400 sized to smaller 350 size diameter) mains to be made into 383's before the aftermarket cranks became popular and more available at lower cost? Ever hear of those original 400 cranks breaking, even in racing applications? Not really an issue, you will be fine with the cast crank in your tow engine. Agree, spend the saved money on a good balancing, that will provide better benefit than the forged vs cast.
    scotty t, Deuces, 31hotrodguy and 2 others like this.
  14. jimmy six
    jimmy six
    For a tow rig.. why stop with a 3.750"... I'd go with a 3.875" or 4" . make a real torquer.
  15. I had a cast crank in my O/T Nova Drag Car. I was young and broke. Spent all my money on the top end. Sportsman 2 heads, Crane Cam, Vic Jr., etc. the bottom end was stock Chevy Truck. Four bolt block, cast crank, stock rods, stock rod bolts. It even had some of those 12to 1 cast “claimer” pistons in it. 4.86 gears in the 9 inch and 7300-7400 through the traps every run for three years until I sold it. For some reason, sometimes stuff that isn’t supposed to work does. By the way, I don’t recommend this. Your results may vary.
    Deuces and 31hotrodguy like this.
  16. Budget36
    Budget36
    Gotta read some:) The truck won't see but 4-5K miles a year. I mean I could go BBC, hell, find a 496 out of pick and pull...heck...I could fit a duramax in it...hell, I could find an old Pete or KW (eff the cab over Whites) and run a big cam 400...I could...
    Well, tis why I'm not. Not going to make a living with it;)
  17. jimmy six
    jimmy six
    Budget, our sporadically used tow rig has a 496 oddball and is a torque monster; 12 mpg empty and 11.5 when towing. On the trailer is a 1/2mile Super Stock dirt Camaro with the 422” all iron Dart.:):):)
  18. deathrowdave
    deathrowdave
    from NKy
    Never heard of a cast steel crank , I was thinking it was a cast ductile iron . I didn’t know it was cast steel . As far as forged , I was very sick ( stage 4 cancer ) , I sent my LT1 forged steel crank to the machine shop , they snapped into 2 pieces . WTH , I went to pick it up , ended up tossing it into the dumpster , installing a cast crank and done . I just had way to much going on to press the shop owed me a crank.
  19. dirty old man
    dirty old man
    I think I would give serious consideration to a big block like a truck 454. Very little stress on engine parts and lots
    of torque.
    But since this is a low budget project, a lot depends on what you already have on hand.
    kidcampbell71 likes this.
  20. sunbeam
    sunbeam
    When you turn down the mains .200 from a 400 you lose a lot of journal over lap I would spring for the better crank. There is a reason Chevrolet increased main size between a 327 to 350 and a 350 to 400.
    Deuces likes this.
  21. jaw22w
    jaw22w
    from Indiana
    What exactly is journal overlap? Never heard of it.
    Deuces likes this.
  22. A cast crank if its a good one will hold up just fine in a tow rig.
    dana barlow, ottoman and Deuces like this.
  23. The 350 in my ride came from a gm 1ton. 11k gvw
    Cast crank from the factory.
    Deuces likes this.
  24. dreracecar
    dreracecar
    from so-cal
  25. sunbeam
    sunbeam
  26. 315,000 miles on a tow happy, 8 passenger, stock, GM crank, 350, 29 year old vehicle.
    Also ... beat to every inch of its life, a turned down, stock GM 400 crank, 383 ... until it blew to kingdom come, after 13 years.
    That vehicle's latest 383, has a high dollar steel crank, amongst other high $ parts ... & I have maybe 500 miles on it since, 2009. Yikes.
    Hope that helps.
  27. jaw22w
    jaw22w
    from Indiana
    Thanks! That is a good explanation. Learn something every day. I just never got into crank design to have heard the term. Racing, I once broke a stock 400 crank right behind #3 main. I also broke a high $$$$ 410 crank in the same place at about 8200 rpm. That one tore up a lot of shit.
  28. Deuces
    Deuces
    Look into '70-'71 gmc or chevy pickups with a 350 4-bbl carb.... The blocks are 4-bolt mains with a forged steel crank.... And heavy duty "X" truck rods..... Allot beefier than car rods......
  29. Budget36
    Budget36
    Good advice, but thinking I'd like to use what I have...hence my original question. Thanks
    Deuces likes this.
  30. MAD MIKE
    MAD MIKE
    from 94577
    Fairly sure the Goodwrench 350 service replacement engines all use a nodular iron crankshaft.
    Cast<Nodular Iron<Cast Steel<4340.
    The cast steel crank is plenty strong for mild performance and midrange useage.
    Deuces and Budget36 like this.
