cast aluminum finish
Discussion in 'The Hokey Ass Message Board' started by Larry T, Apr 26, 2009.
  1. Larry T
    Larry T
    It's been talked about some, but I wanted a natural aluminum finish on an intake that had been modified and this one worked for me.
    I bought a Weiand Team G manifold as a "baseline intake". I really like the way they work (for their intended application), but man they have a lot of extra stuff cast into them. I don't mind folks knowing what it is but Team G in three different places on the intake is a little much. And since this intake won't ever see nitrous the bosses are kinda over the top.
    So to clean the intake up (simpler looking is ALWAYS better), I ground the extra advertising and lumps off of the runners. I worked them down about like I would have if I were going to polish the intake. Then I bought a cheap Harbor Freight needle scaler and went to town on the runners. I was kind of puckered up at first, but found out that you just need to get after it. After I worked at it a little, I was real happy with the results. The shine is a little too much right now, but I figure time will take care of that. Or I might try some sort of aluminum cleaner to even everything out.
    I know this intake is kind of off topic, but it was just an experiment to see if I could "naturalize" aluminum.
    Think of the possibilities!
    Larry T
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Cool - glad that worked well...
  3. Ricks57
    Ricks57
    from San Diego
    Hi,
    I have an old mopar intake I want to do the same thing. So, what is a needle scaler?
    Rick
  4. claymore
    claymore
    Looks much better than it originally did.
  5. kelzweld
    kelzweld
    This. You can also screw the needle attachment onto all the air chisels I've ever come across.
  6. Definitely. [​IMG]
    Nice work.
  7. striper
    striper
    If you hit that with glass bead now I reckon you'd about have it.
    Pete
  8. theHIGHLANDER
    theHIGHLANDER
    There's another way but you need to be very conservative with it. A decent sized carbide burr on a medium speed die grinder. The trick is to let it just "dance" around the ground area, letting the weight of the grinder be the only pressure, or even lighter. Once done you get the same shiney effect as the scaler but it looks as cast. To kill the shine w/out blasting you can apply some high strength wheel cleaner or even some full strength Wesleys Bleech White and let it sit, re-apply and rinse well. If you know someone that can do it cheap enough, you can also shotpeen the outer surfaces and it comes back looking like a new part, but again it's a conservative approach that works best.
    You're right man, plain and clean is the way home on that stuff. Did a Dart intake on a stealthy street racer. To make it look lower I used some old B&B valve cover risers blended into the heads then topped it off with some stock BBC valve covers. I painted everything semi-gloss black and at night you just couldn't see the "money", hell during the day it was real hard to detect. Man that was fun. Good stuff...
  9. RAY With
    RAY With
    I have used close to the same process when making repairs to aluminum intakes. Bottom line is when finished they look as new.
  10. Larry T
    Larry T
    Thanks guys,
    I'm thinking about some "Double Hump" Dart Pro Ones painted orange next. (G)
    Larry T
  11. I agree. I used one on an old Eddy intake that I cleaned up to sell and that worked wonders. It was pretty ratty and corroded. I hit it with a scaler and then a quick blast and it looked brand new.
  12. Shifty Shifterton
    Shifty Shifterton
    Neat tool that a lot of people don't know about. Good writeup!
    I've always wondered if this isn't the tool to use on a stuck engine. Like work the external cast surfaces of the engine for half an hour to remove all the rust and paint while there's penetrant in the cylinder.
  13. dirty old man
    dirty old man
    If you use a blaster and the manifold has a tin shield on the bottom to keep oil off the exhaust heat riser passage across the bottom of the manifold similar to a sbc or sbf stock manifold, be sure to remove the shield before you blast.
    It's usually held on by 2 drive in rivets that can be removed by careful use of a sharp chisel (to start lifting, not cut), then pry them out. They usually have a spiral OD that sort of screws the rivets in.
    Once removed, clean this piece seperately from the manufold. Any engine part cleaned with a blaster that will be exposed to the interior of the emgine must be scrubbed with hot, soapy water, rinsed thoroughly and then blown dry with compressed air. This shit will eat the bearings and journals right out of an engine before a cat can lick it's ass!
    Dave
