I'm rebuilding a Carter YF carb. It's a 3211S. Inside the choke housing is a bar the comes up and is connected to the throttle body via a rod. Well, when it comes into the choke housing it doesn't connect to anything. It makes no sense. I''m pretty sure it is supposed to be coneected dome how. Here's a couple of pics. Let me know what you think. If I'm missing a part I hope I can find it. Thanks, Todd
Choke trip lever, mounts in the shiny hole on the right and is moved by that "hook" That arm sticking out at ya goes through a slot in the sheet metal baffle and picks up the end of the bi-metal spring coil.
I had two of those on a dual intake many years ago. The auto-choke was not a really useful feature. I had the original Carter heat-stove that mounts to the exhaust manifold, but I had to keep fine-tuning the auto choke setting with different ambient temps and eventually just got the universal manual choke conversion kit from Napa, which worked a lot better, as I could control the amount of choke on the dash, if needed. It's a good single carb for the 235, which is basically the same as 2100s/manual choke. Just make sure you don't let E-10 ethanol gas run dry inside the bowl from parking too long in the summer. The accelerator pump diaphragm can harden and crack if it dries out.
Thanks for the info. I have the sheet metal baffle and the plactic cover with the heat spring. I guess I am missing the "trip lever"? I cant find a pic of the complete assembly. Can this be modified to manual choke. I've hade these heat chokes on Rochesters before and they have never worked very consistanly for me. Todd
***UPDATE*** I braved the still shitty roads here and went to the local parts store and got a manual choke conversion kit from Dorman. I think this will be much better than the heat choke in the long run. Thanks again for your inputs. Todd
