Technical Carter AFB flow ratings
Discussion in 'The Hokey Ass Message Board' started by carbking, Dec 2, 2021.
  1. carbking
    carbking
    Some time ago, I posted venturii area for Carter WCFB carburetors. Since then, I have searched the Carter documentation in my possession to do the same for genuine Carter AFB carbs.
    The focus of this article is ONLY on genuine Carter AFB carbs; the modern imitations are not considered regardless of if they are marked Federal Mogul / Webber / Edelbrock / or even Carter. Yes, Federal Mogul tried to market some that were marked Carter, but Carter distributors refused to sell the watered-down versions! If you like the imitations, fine; but I will not even attempt to research them.
    I have totally given up on trying to place a formatted article here, and the site would time out if I attempted to type an article of this length. Thus, I have placed the article on my website with a link:
    https://www.thecarburetorshop.com/AFB_flow_ratings.htm
    Comments are welcome.
    I triple-checked my data, but even so, with this much data, there is probably at least one error somewhere. I have no ego. If one finds an error that can be documented, I will be more than happy to correct the article.
    This will be the last of these articles on Carter 4-barrels. Virtually all of the O/T thermoquads have published data, as do the equally O/T AVS units.
    Jon.
    Papas32, theamcguy, Bob Lowry and 6 others like this.
  2. Tman
    Tman
    Good info, I was just looking for this.
  3. saltracer219
    saltracer219
    Thank you for this great info Jon, it is much appreciated.
  4. carbking
    carbking
    I was disappointed that Carter did not publish catalog pages on the Studebaker AFB carbs, just TFN's. If anyone has any Studebaker literature that can add this, I would appreciate it.
    Jon.
  5. Great information Jon. Thank you
  6. alphabet soup
    alphabet soup
    Thank you again. You ARE the King of Carter carbs. Gene.
    28rpu likes this.
  7. lippy
    lippy
    from Ks
    Thankyou. So much help in identifying carb numbers. Great!!! Lippy
  8. Thanks for the info !
  9. alphabet soup
    alphabet soup
    Jon, is there a real way to determine the correct step-up springs for an application?? Thanks, Gene.
    57 Fargo likes this.
  10. carbking
    carbking
    Gene - if basically an un-modified original application, look up the springs in the original bill-of-material.
    If not stock, then START with the original calibration, and tune from there.
    Jon.
    alphabet soup likes this.
  11. bchctybob
    bchctybob
    More great info, thanks Jon.
  12. alphabet soup
    alphabet soup
