In a std carb kit for a 235 engine, Rochester B, there are two air horn gaskets. The carb rebuikd kit illustration, shows the one to use is the one that has sort of a small dog leg cut-out at the end opposite the needle-valve seat assy (The gasket on the left). Where is the other one used. Possibly a BC? Then I've researched the Old Car Manual Rochester parts list, and I find the p/n for that gasket is 7004480 for just about all 50's carb B's. I don't understand. Can anyone chime in and help me out here? Thanks.
It's not. On a B you need the one with the dog leg. There are some part numbers where the "legless" one is used.
I read somewhere there are well over 100 different Rochester B's. I would not be surprised to find a couple of different gaskets in a universal rebuild kit. I always have. I just use which ever one looks like the one that came out.
